Cant record properly...
ripstein
Post by ripstein »
Hello all.. I am learning to work with my Ultralite MKIII and my Mac Pro G5 and still haven't been able to record anything either with Audio Desk or with Soundtrack, I am connecting a mic to the front connector of the ultralite, and in Cuemix FX I do see the levels meter move ( just a little) with voice on the mic, but the levels that I can record are terribly low.. I think I am doing something wrong, but the manual hasn't been any help... any advice..
regards
Alex
jmadill
Re: Cant record properly...
Post by jmadill »
Is it possible that your Mic requires 48v Phantom power, and the Ultralite is not providing it?
-jm
ripstein
Post by ripstein »
The mic does need the phantom power... and I have the little switch in the front panel to the setting that is supposed to provide it... I will try to record with a powered mic, ( how can I check if the voltage is being provided?)
Alex
ripstein
Post by ripstein »
I have identified my problem... the ultralite is not giving me phantom power for my mic's.. is there some kind of setup to get it going?.. ( I moved the little switch in front, but to no avail).. is my ultralite broken???
thanks
jmadill
Post by jmadill »
Are you using the UltraLite's power supply? I was thinking maybe it can't provide phantom power when using it bus powered ...
-jm
ripstein
Post by ripstein »
I tried it both with firewire power and also with the external power supply... but it wouldn't work...
Alex
