Where is Kontakt output 1-2 in V-Rack?
So I have a copy of Kontakt loaded up on an instrument track in V-Rack1. In the Bundles window I only see Kontakt outputs 3-16. How do I get at outputs 1-2?
Thanks,
Jason
www.chromasound.net
Thanks,
Jason
www.chromasound.net
Jason Staczek
www.chromasound.net
Dual 2.5G G5, 6.5G RAM, DP 5.13, OS 10.4.11
MBP 17", 3G RAM, DP 5.13, OS 10.4.11
Pro Tools HD2 Accel, 828mkII, FastLane, Logic 8
www.chromasound.net
- qo
Re: Where is Kontakt output 1-2 in V-Rack?
What does your audio bundles (instrument tab) look like? I've seen the same problem with BFD. I really haven't tried other multi-out AU's but perhaps this happens with all of them? Maybe a DP bug?
Instruments tab only shows 3-16. Seems like outs 1-2 always come straight out the instrument track to whatever its output is assigned to. Do you have to send them to a bus to use them elsewhere maybe?
Jason
Jason
Jason Staczek
www.chromasound.net
www.chromasound.net
No one else using Kontakt and multiple outs in DP4.6 out there? Surely I'm not the only one....
Jason Staczek
www.chromasound.net
www.chromasound.net
- qo
I just tried it using Kontakt2 and get the same thing. But, this also happens for BFD, so I think it's just a DP thing. In Kontakt, you can determine which of its "physical" outputs (the outputs it advertises to DP) are used for a given patch. Just make sure that the patch isn't sending to outputs 1 or 2 and you'll be fine.
i have the same "bug?"
Shane Fontane
www.shanefontane.com
Dual 1.8 G5 | 2.5GB | OS X 10.3.9 | DP 4.52 | UAD | Mach 5 | SampleTank 2 | Kontakt 2 | MX4 | Recycle | MAudio Firewire Audiophile | Undying Passion For Music
So it looks like a bug, then. I have to lose 2 of my 16 outs? 1-2 seem to come out of the instrument track. I guess I could buss that somewhere else if need be...
Jason
Jason
Jason Staczek
www.chromasound.net
www.chromasound.net
This is not a bug. The Instrument track (itself) is outputs 1-2 for the instrument. The instrument track can be bussed and printed to a stereo track (as you know). Mutiple outs beyond that start with 3 on up...
Cheers
Cheers
- qo
Thanks for the clarification motuhelper. Do you work for MOTU? If so, (and even if not so), it's good having you around!
So not a bug, but just an inconvenient inconsistency. It would make a lot more sense for 1-2 to show up in the Instruments tab of the Bundles dialog so you could handle them like the rest of the outputs. It's a little weird to have buss them separately.
Thanks,
Jason
Thanks,
Jason
Jason Staczek
www.chromasound.net
www.chromasound.net
Let's just say...
I'm Magic Dave's third cousin.
- qo
Originally posted by motuhelper:
Let's just say...
