Digital Performer 6.02 is now shipping. If you own Version 6, you can download the free Version 6.02 updater. This maintenance release includes numerous program enhancements and optimizations, including the new configurable Shortcuts window, the new options for floating the main Control Panel and setting its level of transparency, automatic versus manual note durations in the QuickScribe Editor, more customizable key bindings and many more.
DP 6.02 is up
DP 6.02 is up
http://www.motu.com/newsitems/digital-p ... w-shipping
- Dan Walsh
Re: DP 6.02 is up
SWEEEEEETTTTTT!!!!!!!!!
iMac 3.06 i3|OSX 10.6.8|8 gig ram||DP 7.24|Motu 896HD|2 Avalon VT 737's|Presonus ADL600|Slate VCC|Superior Drummer 2|EZ Drummer|1.1.6|Kontakt Player 4.1|Steven Slate Drums EX|SampleTank 2 XTAntares ATR-1|Presonus Central Station|Neumann TLM 103|Rode NT1|Audio Technica AT 4033 X2| Rode NT-5's|and lot's of other junk
Re: DP 6.02 is up
nice...
downloading
downloading
Re: DP 6.02 is up
Re: DP 6.02 is up
Not seeing the link here. Are you guys just logging into your MOTU acct? Maybe a call is in order. The registration shows correctly.
- Dan Walsh
Re: DP 6.02 is up
The update seems to be workin' fine so far. I have lost my DarkMod though. I assume I can swap out the respective XML files from from 6.01 and that should work? Any advice?
Re: DP 6.02 is up
Could this be Intel only?! I still don't see the download when accessing from my account.
Re: DP 6.02 is up
Great!
MacPro 2.66 - 8Go ram-10.6.2 /DP7.2/URS plugs/Kontakt4/PlugsoundPro/StylusRMX/EZDrummer/Superior/Altiverb/Ozone4/Sonnox/etc...Neve 8801/RME ffce 800
- corbo-billy
Re: DP 6.02 is up
Me too! Then try the link with the first message in this topic _
Save the files on your GUI if you want to find then !
Re: DP 6.02 is up
Well duh! Thanks a bunch, that seems to have worked. I guess the links to the registrations will follow later. I ain't waitin'!corbo-billy wrote:Me too! Then try the link with the first message in this topic _
Oh baby! It's Christmas (I hope).
Re: DP 6.02 is up
hallelujah! i hope this is it for DP 6... ie: it works..
does anyone know where a full Read-Me can be found of the new features and fixes? didn't find one after i ran the updater..
Re: DP 6.02 is up
Same here fingers crossed.taylor12k wrote:hallelujah! i hope this is it for DP 6... ie: it works..
Re: DP 6.02 is up
Go to the Help menu in DP and select 'New Features In Digital Performer 6', and it launches the PDF. Since the PDF is stored somewhere in the app, I saved a copy to my desktop for printing or for reading when DP wasn't launched. (The instructions for finding this are easy to miss - they're in the Read-Me which appears at the start of installation.)taylor12k wrote:does anyone know where a full Read-Me can be found of the new features and fixes? didn't find one after i ran the updater..
This is a new approach for MOTU. In DP 5 and earlier, the installer used to put the PDF - and maybe the Read Me file too, I don't recall - on your desktop or in the DP application folder (which is no longer used).
Bob
DP 11.23
Metric Halo ULN-8 mk4
DP 11.23
Re: DP 6.02 is up
When you run the updater, one of the first screens is the READ ME. From there you can save or print. I choose to save and copied from the text file:taylor12k wrote:hallelujah! i hope this is it for DP 6... ie: it works..
Digital Performer 6.02 Read Me
Thank you for installing Digital Performer 6.02.
For a more comprehensive list of new updates, please refer to New Features in DP 6.pdf, available under Digital Performer's Help menu.
OS X 10.5 Leopard Compatibility:
Digital Performer 6.02 is fully compatible with OS X 10.5 Leopard.
Minimum System Requirements:
Digital Performer 6 requires a G4 1GHz Power Mac with 1 GB RAM running Mac OSX 10.4.7 (Tiger) or higher to install and run. A 17-inch (or larger) monitor is highly recommended.
Universal Binary:
This version of Digital Performer is fully compatible with Intel based Mac systems, as well as PowerPC-based G4 and G5 Mac computers.
Pro Tools | HD System Requirements:
Digital Performer supports DAE version 7.2 or later with the following Digidesign Pro Tools systems:
• Pro Tools | HD (1, 2 or 3)
• Pro Tools | HD Accel
As new versions of Pro Tools/DAE are released please check http://www.motu.com for qualification updates.
Users of previous versions of Digital Performer
Please refer to chapter 10 in the Digital Performer Getting Started Guide for information on new features and changes from previous versions of DP.
Additionally, please note that the Digital Performer application is now installed directly into the Applications folder. The following items have been moved or removed:
• The "Clicks" and "Grooves" folders have moved to /Library/Application Support/MOTU/Digital Performer. Move any custom click or groove files from previous versions into these folders.
• Extras folder:
- Expansion Board Setup.app has been removed. To configure expansion boards for your MIDI devices, go to the Bundles window, select the MIDI Devices tab, and open the device's Properties window to the Patches tab.
- FreeMIDI Converter.app is no longer included. Please use Audio MIDI Setup to configure your virtual studio manually.
- The "Use me to calibrate your audio" project is no longer included.
Changes and new features in Versions 6.01 and 6.02
Please see New Features in DP 6 for details on the following:
Version 6.02
• QuickScribe enhancements
• Control Panel transparency and float options
• Audio File preferences
• Audio recording error preference
• Tracks Window divider
• Soundbite Window scroll bar
• Realtime hours field
• Virtual port connections for Control Surfaces
• Markers menu
• Shortcuts window
• Final Cut Pro XML Import alerts
• Command & key binding changes
• Other miscellaneous changes
Version 6.01
• Configuring the Information windows and Information Bar
• Selection Information window
• Track Inspector
• Plug-in real-time preferences
• Final Cut Pro XML Import & Export
• CoreMIDI Patch Thru
• Snapshot button
• Consolidated Window body row close buttons
Thank you. We hope you enjoy using Digital Performer 6. We welcome your comments and suggestions.
Sincerely,
The Digital Performer Development Team
http://www.motu.com/techsupport
http://www.motu.com/suggestions
Re: DP 6.02 is up
MLC, you stole the spotlight from my post!
The 'New Features' PDF has much more detailed info than the PDF. Unlike previous versions of DP, which saved it onto your desktop or Applications folder, it's kept in the DP Help menu.
Bob
DP 11.23
DP 11.23
