In DP6.01, open your plugin. In the upper right corner click and hold on the triangle with the circle around it.NealF wrote:I looked in Preferences, General, Audio Pluggins and couldn't find anything that gives the option to run in real time. Global or otherwise.
Am I looking in the right place?
"Run this instance in real-time" works on a plugin-by-plugin basis.
"Default to real-time" appears to be a global setting. It's a little confusing because they are in the same place, but whenever I've tried "default to real-time", all instances of a particular plugin have automatically been set to the same real-tim default.
As for the Preferences, take another look. (This is DP6.01.) Scroll down to GENERAL and the second item is "Audio Plug-ins". If you look at the bottom of the darker gray area, you'll see the following options:
-- Default for new projects: "pre-gen mode when possible", "virtual instruments in real-time", and "all plugins in real-time"
--Current project: same options as listed under "default for new projects".
