Hi
Please could someone pose a scenario for this. I record and edit at 96khz but need to output an SPDIF connection at 48khz on my ultralite mk2. I ran out of audio input so need to make this work. I use cubase sx and live if they have there own internal methods (unable to locate any solution in docs). Where in the audio chain would i need to resample. Will this work if the ultralite is at 96khz and I resample a single out to 48khz then route it to the SPDIF. Would i need an external resampler (expensive no doubt?). Looking for a software solution, no patchbay in sight aswell.
Paul.
Ultralite at 96khz but need simultaneous SPDIF out at 48khz
Re: Ultralite at 96khz but need simultaneous SPDIF out at 48khz
So we can better understand this, Why do you need to have one output at 48k?
Hi
Trying to use all my available inputs. Have spdif on D-Two delay. All my analogue ins are used by other equipment, so all that is left is the spdif connections.
Thanks.
Thanks.
Still Confused as to what you are trying to do? The more details the better!
