How do you connect outboard
Compressors like the DBX 160A or Distressor or Mic Pre or MIDI Keyboard to the Motu? Do I need a seperate Mixer or Patch Bay?
- TheRealRoach
Re: How do you connect outboard
Depends on what you want to do and what MOTU units you have.
If you have enough analog inputs and outputs then you don't necessarily need a mixer.
Mike Rocha
http://www.mikerocha.ca
Custom ADK, Quad 3.0ghz, 4gig ram, Win7 64-bit, Motu 3.6.7.3 x64 drivers
Macbook Pro 13" touchbar, High Sierra, 73220 drivers
Motu 896 x 4
Motu 896 x 4
Motu 828 MKII. I want to connect 2 Compressors, a Mic Pre, and a MIDI Keyboard.
- TheRealRoach
You're good to go then. Just make sure you used balanced cables with TRS connectors.
Mike Rocha
Motu 896 x 4
Motu 896 x 4
- DJ Synchro
- Primary DAW OS: Windows
Just connect the input(s) of the compressor to one of the outputs of your MOTU and the output(s) of the compressor to one of the inputs of the MOTU unit. Then setup your sequencer to use that busses for the compressor. A synth can be connected to two inputs of the MOTU unit. The your good to go.junkiexl2000 wrote:Compressors like the DBX 160A or Distressor or Mic Pre or MIDI Keyboard to the Motu? Do I need a seperate Mixer or Patch Bay?
LINKS: Website | Facebook | Twitter | Studio
GEAR LIST: Intel Core i7 3820 computer with 12GB Corsair DDR3 1333Mhz RAM. Asus P9X79 Motherboard. 3x Crucial M4 SSDin RAID 0. Dual Full HD monitors. PCI424 with MOTU 24IO. MOTU MIDI Express 128 USB. Steinberg Cubase Pro 8. Various VST plugins. Steinberg Houston DAW controller. Clavia Nord Rack 2x. Yamaha CS-1X. Behringer Eurodesk MX2442. Akai s2000 sampler. Roland MC-303 Groovebox. Various outboard.
How about Cables? Say if i want to connect 3 Compressors that have XLR input/outputs. How do I connect them to the Motu? Where can I find these cables...link? How many of each do I need?
http://www.musiciansfriend.com/navigati ... G&ZYXSEM=0
http://shop.ebay.com/?_from=R40&_trksid ... xlr+to+trs
anyone wanna narrow down my search?
