Checklist for Record enable audio?
pjmnash
Post by pjmnash »
I'm trying to figure out why my track won't let me record enable or record. I keep checking transmit/receive etc and my interface is listed on the track sheet but what's wrong? :roll:
Could someone please list a checklist of Go i.e. Record precedures?
Thanks,
The lady in Texas
1nput0utput
Re: Checklist for Record enable audio?
Post by 1nput0utput »
If it's a MIDI track and Multi Record is disabled, the track must have an output assignment.
If it's a MIDI track and Multi Record is enabled, the track must have an input assignment and an output assignment.
If it's an audio track, it must have a valid input assignment and a valid output assignment, and the track must be enabled.
The audio system must be MAS or DAE; audio tracks can not be record-enabled in MIDI only mode.
Eleventh Hour Sound
Post by Eleventh Hour Sound »
pjmnash wrote:I'm trying to figure out why my track won't let me record enable or record. I keep checking transmit/receive etc and my interface is listed on the track sheet but what's wrong? :roll:
Thanks,
The lady in Texas
Try opening the MOTU demo sequence and see if you're able to play it back and hear it . If so, your audio outputs should be ok. Then try selecting a valid audio input channel on one of the mono audio tracks and then try to record.
The manual can be helpful too :)
DP11.1, 16" MacBookPro 2.3Ghz 8 Core i9's 32GB Ram 1TB SSD, (2) external 1TB Samsung SSD's , Steven Slate SSD 5.5 and Trigger Drums, ML-1 Mic and VSX Headphones, Omnisphere 2, Trilian, Ivory2, EW, MSI, MX-4, Philharmonik 2, Komplete, Reason, Live, Melodyne, IK Multi's Total Studio, ARC, T-RackS, SampleTron, AMG's KickA--Brass. and my beloved guitars :-)
SixStringGeek
Post by SixStringGeek »
The usual culprit is the track has no valid output - if the output is in italics - its not valid. Choose something else.
DP 11.newest on MacBook Air M2 24/2T
Korg Kronos Klassic Keyboard 88, Line 6 Helix
