Talking about getting that juicy,fat and wide guitar sound.
What is your tips&tricks in getting that?
The way I see it is that there are 2 options to do this;
eiter create several tracks, 4-5-6-7-8 +++ playing the same riff/chords and just pan them occasionnaly LRC, and maybe some different eq settings
OR: just copy and paste the same recorded track into new tracks and adding effects.
What is the pros and cons with these two?
Any tips??
dub tracks several times or just copy and paste??
Rig:
AMD phenom quadcore
4gb DDR2 ram
1x750gb hd
1x500gb hd
an ok grapic card with 2 outputs
Motu 896mk3
Phonic P8A monitors
Pod XT pro guitar multifx processor
Korg Triton Studio synth
Rode K2 tube mic
Several different guitars (guitar is my main instrument)
AMD phenom quadcore
4gb DDR2 ram
1x750gb hd
1x500gb hd
Motu 896mk3
Phonic P8A monitors
Rode K2 tube mic
Re: dub tracks several times or just copy and paste??
I've found I prefer to record several diff tracks rather than copying and pasting. I'll record one track and then maybe change the settings on the amp treble, bass, mid ect and record another track or use a diff amp/guitar altogether. Then blend those together. It's fun to record the same track with diff amps and guitars sometimes and blending these will produce a nice fat sound. Or same thing with plug ins if you can't mic an amp up. Panning is left to whatever the song is calling for.
Tho sometimes you get a real good track and you want to copy and paste it. I tend to stay away from this tho and I will only copy and paste one track as it starts to sound like mush even after eq'ing and phase problems can occur. I don't have a set pattern I use as I'm always experimenting with diff ways of doing things to get a fat sound but copying and pasting is not one of my favorites.
- timriley
Also, using several different mikes on the same amp might give you the desired results.. Have them in different positions in the room, some away from the cab, some close......
Mac Pro Quad XEON/2.8Ghz/12GB RAM
Macbook Pro Core Duo/2.16Ghz/2GB RAM
OSX 10.6.8/DP7.22
OSX 10.6.8/DP7.22
- BradLyons
- Primary DAW OS: Windows
Copying and Pasting is faster and easier, but you know that saying....... DO THE SAME THING and EXPECT THE SAME RESULTS. Simply doing this will sound like the same track stacked, but what makes the track come alive is the variance of change. Take ENYA for example, she does something like 200 vocal tracks all layered and stacked, yet it sounds like one track that is HUGE!
Thank you,
Brad Lyons
db AUDIO & VIDEO
-Systems Advisor, CTS
Brad Lyons
db AUDIO & VIDEO
