Word Clock thru BNC
Word Clock thru BNC
Anyone know if there's a maximum length of cable for word clock thru BNC?
Macbook Pro Aluminum 2.4GHz, 4GB, 500GB, DP 6.02
828MkII FW, 8pre
828MkII FW, 8pre
Re: Word Clock thru BNC
I think a word clock signal is about the same amplitude as a line level audio signal, so I would follow the same guidelines as for line level analog. Hosa makes word clock cables up to 100 feet. I think you would encounter interference and signal degradation with cables much longer than that.
- therealbigd
not to mention jitter. longer cable runs always encounter more jitter.
what devices are you clocking together? you should run the clock master from the weakest source.
Just remember kiddies, You can't polish a turd.
Macbook Pro 2.4GHz 15" i5 + MBP 2.4 15" C2D, MOTU 828mkII FW (Logic 9), Wilson Benesch Arcs + Cyrus Amps; PMC DB1S+ & MC2 Amps; REL Acoustics Strata 5 Sub.
At the moment, I have an 828MkII and a Digimax LT. I'm hoping to replace the Digimax with an 8Pre. Also in the chain is an Ultralite MkIII. I'm hoping I can send word clock to that via SPDIF at the same time.
828MkII FW, 8pre
828MkII FW, 8pre
Neither the 8pre nor the UltraLite mk3 have word click I/O. You can synchronize them to the 828mkII by ADAT optical and S/PDIF, respectively, or they can synchronize to each other over the FireWire connection.gvarlotta wrote:At the moment, I have an 828MkII and a Digimax LT. I'm hoping to replace the Digimax with an 8Pre. Also in the chain is an Ultralite MkIII. I'm hoping I can send word clock to that via SPDIF at the same time.
Yeah, I was going to connect the 8Pre with the ADAT optical. If I go the FireWire route, doesn't that give each individual unit it's own CueMix console? I'd like to have them all together.1nput0utput wrote: Neither the 8pre nor the UltraLite mk3 have word click I/O.
828MkII FW, 8pre
828MkII FW, 8pre
- therealbigd
i dont think you can clock them over firewire can you?1nput0utput wrote:Neither the 8pre nor the UltraLite mk3 have word click I/O. You can synchronize them to the 828mkII by ADAT optical and S/PDIF, respectively, or they can synchronize to each other over the FireWire connection.gvarlotta wrote:At the moment, I have an 828MkII and a Digimax LT. I'm hoping to replace the Digimax with an 8Pre. Also in the chain is an Ultralite MkIII. I'm hoping I can send word clock to that via SPDIF at the same time.
Yes, the MOTU driver supports synchronization over the FireWire connection.therealbigd wrote:i dont think you can clock them over firewire can you?1nput0utput wrote:Neither the 8pre nor the UltraLite mk3 have word click I/O. You can synchronize them to the 828mkII by ADAT optical and S/PDIF, respectively, or they can synchronize to each other over the FireWire connection.gvarlotta wrote:At the moment, I have an 828MkII and a Digimax LT. I'm hoping to replace the Digimax with an 8Pre. Also in the chain is an Ultralite MkIII. I'm hoping I can send word clock to that via SPDIF at the same time.
