Sessions I made in Tiger crash in Leopard
pietervd
Post by pietervd »
hi there
i have a problem and here's the situation:
i have a G5 with a motu ultralite and a mac pro with a motu ultralite.
one has tiger, the other the latest leopard version.
i never had problems, but suddenly, the sessions i started on the G5 (tiger) don't open on the mac pro. DP starts, but before i see my session it crashes.
however: i can open every sesson in MIDI ONLY mode.
and i still can open DP on the mac pro and create a new session...
weird huh?
anyone has a clue???
pietervd
Post by pietervd »
and both computers have DP 5.13.
Phil O
Post by Phil O »
I had that problem when I first installed Leopard. I don't know where the problem was but in frustration I started from scratch and re-installed both Leopard and DP and the problem went away. I realize that's not much help except to say that it could be a bad install of something.
philbrown
Post by philbrown »
Your topic title says "Leopard" but your post says you're running Tiger on both machines:
one has tiger, the other the latest tiger version.
pietervd
Post by pietervd »
philbrown wrote:Your topic title says "Leopard" but your post says you're running Tiger on both machines:
sorry you're right.
i meant leopard on the mac pro!
cheers, i'll edit it.
pietervd
Post by pietervd »
Phil O wrote:I had that problem when I first installed Leopard. I don't know where the problem was but in frustration I started from scratch and re-installed both Leopard and DP and the problem went away. I realize that's not much help except to say that it could be a bad install of something.
hi phil
do you think it has something to do with avoiding software update?
Phil O
Post by Phil O »
pietervd wrote:hi phil
I have no idea. I've always used software update and never had a problem with it. Some people swear by the stand alone installers. I just don't know.
pietervd
Post by pietervd »
i'm reinstalling leopard now. i'll stick to 10.5.1 if DP works fine.
Lookinnn
Post by Lookinnn »
hhmm .. i have a mac pro 8 core and my tiger sessions run fine.
i just copied 7 sessions over the network and opened them on the leopard machine and all is fine ..
you might have some plugins in the session that are crashing.
anyways .. good luck ..
jeff
Mac Pro Dual Quad Core | DP 5.13 | Motu 2408 Mk3 | Motu 24i | TUBE GEAR |
pietervd
Post by pietervd »
so right now it's working fine for you in 10.5.4?
Phil O
Post by Phil O »
Yep. In fact, it's working so well that I'll be hesitant to update if 10.5.5 comes out.
pietervd
Re: Sessions I made in Tiger crash in Leopard
Post by pietervd »
i happens again on my leopard mac pro...
i can start new sessions but the ones i saved in tiger on another computer crash... very annoying.
if somebody can give me new insights... be my guest ;)
Mr_Clifford
Post by Mr_Clifford »
pietervd wrote: the sessions i started on the G5 (tiger) don't open on the mac pro. DP starts, but before i see my session it crashes.
Usually that's a corrupted plug-in (or plug-in data). Possibly the data from a plug-in in Tiger is incompatible with the Leopard version on your Mac Pro. Start up in 'safe mode' (hold down option when starting DP), and then troubleshoot which plug-in is causing you the problem.
pietervd
Post by pietervd »
that's it! thanks a lot.
you're awesome.
Isn't he? The avatar, dashing as it is, doesn't do Cliff justice; he's our resident rugby-lovin' he-man. LOL
