Hello!
More and more i work with Equalisation in Cue Mix FX. I found out, that it is not possible to make precise Adjustments ... I want to cut exactly 110 Hz, the position of the Frequenz Handle snaps to 111, 112, 108 and no way to fix it with the knobs. Withot precise adjustment the filter is worthless for me. Am i alone with this observation, or is there a feature to fine adjust or type in the parameters?
thanks an all the best
Motu828 MKIII EQ Problem
Re: Motu828 MKIII EQ Problem
On the front panel you can adjust each EQ band's center frequency by 10Hz increments between 20Hz and 1kHz.
Thank you for the answer!
I can´t believe this.... so the filter section is useless for me... or would you say: this is a very musical adjustment for frequencies... you can´t bring up or down the frequenz you need, but 10Hz higher or below it sounds much better??????? There should be a fix...
greets
greets
I don't know if this works because I don't have a MkIII, but in DP's MW Equaliser holding Command while mousing gives a finer control.... worth a try.....
but that is on a Mac, so I don't know for Windows..... I guess I'm not much help then!!!!!
Cheers
Stephen
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Nothing helps.... tried every combination .... but anyway thanks for your response
greets
yeti
greets
yeti
Hello
Can anybody confirm this as problem, or is fineadjustment of equalizers not so important for you?
greets
yeti
greets
yeti
