well yes and no.... ts done in xml text format outside the Cuemix, so that would mean exiting cuemix apply changes in new xml-paste that back- start cuemix... etc.. not very slick imhopeddap wrote:Thanx for this "update"reeper wrote:update: *polished* gui![]()
Can't you find a way for us users to label the different channels and mixes?![]()
Regards
Peter
-it CAN be edited tho np. maybe do a installer forit ...but i dont think so timewize
<?xml version="1.0" encoding="UTF-8" ?>
- <resource_list>
- <XSET name="LocalizedStrings">
- <!-- Menu Items ///////////////////////////////////////////////////////////
- <!-- File Menu
<TEXT name="File">File</TEXT>
<TEXT name="SaveHardwarePresetMenu">Save Hardware Preset...</TEXT>
<TEXT name="LoadHardwarePresetMenu">Load Hardware Preset...</TEXT>
<TEXT name="SaveToFile">Save To File...</TEXT>
<TEXT name="LoadFromFile">Load From File...</TEXT>
<TEXT name="Edit Channel Names...">Edit Channel Names...</TEXT>
<TEXT name="Peak Hold Time">Peak Hold Time</TEXT>
<TEXT name="Mix 1 Return Includes Computer Output">Mix 1 Return Includes Computer Output</TEXT>
<TEXT name="Show Meter in Dock Icon">Show Meter in Dock Icon</TEXT>
<TEXT name="HardwareFollowsConsole">Hardware Follows Console Stereo Settings</TEXT>
<TEXT name="Close">Close</TEXT>
- <!-- Load/Save Hardware Preset Popup Windows
<TEXT name="LoadHardwarePreset">Load Hardware Preset</TEXT>
<TEXT name="LoadPreset">Load Preset</TEXT>
<TEXT name="SaveHardwarePreset">Save Hardware Preset</TEXT>
<TEXT name="PresetName">Preset Name</TEXT>
<TEXT name="PresetNameTooLongError">(can not be more than 12 characters)</TEXT>
<TEXT name="OverwritePreset">Overwrite Preset</TEXT>
<TEXT name="Preset">Preset</TEXT>
- <!-- Peak Hold Time Menu
<TEXT name="Off">Off</TEXT>
<TEXT name="2 Seconds">2 Seconds</TEXT>
<TEXT name="4 Seconds">4 Seconds</TEXT>
<TEXT name="10 Seconds">10 Seconds</TEXT>
<TEXT name="1 Minute">1 Minute</TEXT>
<TEXT name="5 Minutes">5 Minutes</TEXT>
<TEXT name="Infinite">Infinite</TEXT>
- <!-- Edit Menu
<TEXT name="Edit">Edit</TEXT>
<TEXT name="Undo">Undo</TEXT>
<TEXT name="Redo">Redo</TEXT>
<TEXT name="Copy">Copy</TEXT>
<TEXT name="Paste">Paste</TEXT>
<TEXT name="ClearPeaks">Clear Peaks</TEXT>
- <!-- Devices Menu
<TEXT name="Devices">Devices</TEXT>
- <!-- Configurations Menu
<TEXT name="Configurations">Configurations</TEXT>
<TEXT name="CreateNew">Create New...</TEXT>
<TEXT name="Save">Save</TEXT>
<TEXT name="SaveTo">Save To...</TEXT>
<TEXT name="Delete">Delete...</TEXT>
<TEXT name="Import">Import...</TEXT>
<TEXT name="Export">Export...</TEXT>
- <!-- Config Manager Popup Windows
<TEXT name="CreateConfiguration">Create configuration</TEXT>
<TEXT name="ConfigurationName">Configuration name:</TEXT>
<TEXT name="DeleteConfiguration">Delete configuration</TEXT>
<TEXT name="DeleteThisConfiguration">Delete this configuration:</TEXT>
<TEXT name="SaveToConfiguration">Save to configuration</TEXT>
<TEXT name="SaveToThisConfiguration">Save to this configuration:</TEXT>
<TEXT name="SelectAConfiguration">Select a configuration</TEXT>
<TEXT name="NoConfigurationsFound">No configurations found</TEXT>
<TEXT name="ok">ok</TEXT>
<TEXT name="cancel">cancel</TEXT>
- <!-- Talkback Menu
<TEXT name="Talkback">Talkback</TEXT>
<TEXT name="ConfigureTalkbackListenback">Configure Talkback/Listenback...</TEXT>
<TEXT name="Toggle Talkback">Toggle Talkback</TEXT>
<TEXT name="Toggle Listenback">Toggle Listenback</TEXT>
<TEXT name="Talk">Talk</TEXT>
<TEXT name="Listen">Listen</TEXT>
<TEXT name="Done">Done</TEXT>
- <!-- Phones Menu
<TEXT name="Phones">Phones</TEXT>
<TEXT name="Follow Active Mix">Follow Active Mix</TEXT>
- <!-- Control Surfaces Menu
<TEXT name="Control Surfaces">Control Surfaces</TEXT>
<TEXT name="Application Follows Control Surface">Application Follows Control Surface</TEXT>
<TEXT name="Share Surfaces with Other Applications">Share Surfaces with Other Applications</TEXT>
<TEXT name="Enabled">Enabled</TEXT>
<TEXT name="Configure...">Configure...</TEXT>
- <!-- Undo Names ///////////////////////////////////////////////////////////
- <!-- Input Undo Names
<TEXT name="Adjust Trim">Adjust Trim</TEXT>
<TEXT name="Set Pad">Set Pad</TEXT>
<TEXT name="Set Boost">Set Boost</TEXT>
<TEXT name="Set Input Level">Set Input Level</TEXT>
<TEXT name="Set Phase">Set Phase</TEXT>
<TEXT name="Edit Channel Name">Edit Channel Name</TEXT>
<TEXT name="Set Stereo Pair">Set Stereo Pair</TEXT>
<TEXT name="Set Stereo Swap">Set Stereo Swap</TEXT>
<TEXT name="Set Stereo Mode">Set Stereo Mode</TEXT>
<TEXT name="Set Stereo Width">Set Stereo Width</TEXT>
<TEXT name="Set Limit">Set Limit</TEXT>
<TEXT name="Set Lookahead">Set Lookahead</TEXT>
<TEXT name="Set Soft Clip">Set Soft Clip</TEXT>
- <!-- Bus Input Undo Names
<TEXT name="Set Solo">Set Solo</TEXT>
<TEXT name="Set Mute">Set Mute</TEXT>
<TEXT name="Adjust Pan">Adjust Pan</TEXT>
<TEXT name="Move Fader">Move Fader</TEXT>
<TEXT name="Set Balance/Width Preference">Set Balance/Width Preference</TEXT>
- <!-- Bus Undo Items
<TEXT name="Set Bus Assign">Set Bus Assign</TEXT>
<TEXT name="Set Bus Mute">Set Bus Mute</TEXT>
<TEXT name="Move Bus Fader">Move Bus Fader</TEXT>
<TEXT name="Edit Bus Name">Edit Bus Name</TEXT>
- <!-- Output Undo Names
<TEXT name="Edit Output Name">Edit Output Name</TEXT>
- <!-- Device Undo Names
<TEXT name="Set Input Pre/Post">Set Input Pre/Post</TEXT>
<TEXT name="Set Monitor Level">Set Monitor Level</TEXT>
<TEXT name="Set Talkback Input">Set Talkback Input</TEXT>
<TEXT name="Set Listenback Input">Set Listenback Input</TEXT>
<TEXT name="Set Talkback Att. Level">Set Talkback Att. Level</TEXT>
<TEXT name="Set Listenback Att. Level">Set Listenback Att. Level</TEXT>
<TEXT name="Set Talkback Width">Set Talkback Width</TEXT>
- <!-- EQ Undo Names
<TEXT name="Set EQ Enable">Set EQ Enable</TEXT>
- <!-- EQ Band Undo Names
<TEXT name="Set EQ Frequency">Set EQ Frequency</TEXT>
<TEXT name="Set EQ Gain">Set EQ Gain</TEXT>
<TEXT name="Set EQ Q">Set EQ Q</TEXT>
<TEXT name="Set EQ Band Enable">Set EQ Band Enable</TEXT>
<TEXT name="Set EQ Type">Set EQ Type</TEXT>
- <!-- Dynamics Undo Names
<TEXT name="Set Dynamics Enable">Set Dynamics Enable</TEXT>
- <!-- Compressor Undo Names
<TEXT name="Set Compressor Enable">Set Compressor Enable</TEXT>
<TEXT name="Set Compressor Threshold">Set Compressor Threshold</TEXT>
<TEXT name="Set Compressor Ratio">Set Compressor Ratio</TEXT>
<TEXT name="Set Compressor Attack">Set Compressor Attack</TEXT>
<TEXT name="Set Compressor Release">Set Compressor Release</TEXT>
<TEXT name="Set Compressor Trim">Set Compressor Trim</TEXT>
<TEXT name="Set Compressor Detector Mode">Set Compressor Detector Mode</TEXT>
- <!-- Leveler Undo Names
<TEXT name="Set Leveler Enable">Set Leveler Enable</TEXT>
<TEXT name="Set Leveler Mode">Set Leveler Mode</TEXT>
<TEXT name="Set Leveler Gain Reduction">Set Leveler Gain Reduction</TEXT>
<TEXT name="Set Leveler Makeup Gain">Set Leveler Makeup Gain</TEXT>
- <!-- Reverb Send / Return Undo Names
<TEXT name="Set Reverb Send">Set Reverb Send</TEXT>
<TEXT name="Set Reverb Return">Set Reverb Return</TEXT>
<TEXT name="Set Reverb Send Pan">Set Reverb Send Pan</TEXT>
- <!-- Master Page Undo Names
<TEXT name="Set Monitor Enable">Set Monitor Enable</TEXT>
<TEXT name="Enable Talkback Output">Enable Talkback Output</TEXT>
<TEXT name="Enable Listenback Output">Enable Listenback Output</TEXT>
- <!-- Reverb Algo Undo Names
<TEXT name="Set Reverb Enable">Set Reverb Enable</TEXT>
<TEXT name="Set Reverb Split Point">Set Reverb Split Point</TEXT>
<TEXT name="Set Reverb Time">Set Reverb Time</TEXT>
<TEXT name="Set Reverb Pre-Delay">Set Reverb Pre-Delay</TEXT>
<TEXT name="Set Reverb Cut Frequency">Set Reverb Cut Frequency</TEXT>
<TEXT name="Set Reverb Cut Level">Set Reverb Cut Level</TEXT>
<TEXT name="Set Reverb Reflections Size">Set Reverb Reflections Size</TEXT>
<TEXT name="Set Reverb Reflections Set">Set Reverb Reflections Set</TEXT>
<TEXT name="Set Reverb Reflections Level">Set Reverb Reflections Level</TEXT>
<TEXT name="Set Reverb Frequency">Set Reverb Frequency</TEXT>
<TEXT name="Set Reverb Width">Set Reverb Width</TEXT>
- <!-- Other Undo Names
<TEXT name="Paste Mix Bus">Paste Mix Bus</TEXT>
<TEXT name="Load Config File">Load Config File</TEXT>
- <!-- Widget Names /////////////////////////////////////////////////////////
- <!-- Tab Strings
<TEXT name="INPUTS">INPUTS</TEXT>
<TEXT name="MIXES">MIXES</TEXT>
<TEXT name="OUTPUTS">OUTPUTS</TEXT>
<TEXT name="CHANNELTAB">CHANNEL</TEXT>
<TEXT name="EQTAB">EQ</TEXT>
<TEXT name="DYNAMICSTAB">DYNAMICS</TEXT>
<TEXT name="METERTAB">METERS</TEXT>
<TEXT name="REVERBTAB">REVERB</TEXT>
- <!-- Inputs Page
<TEXT name="FOCUS">FOCUS</TEXT>
<TEXT name="MONO">MONO</TEXT>
<TEXT name="STEREO">STEREO</TEXT>
<TEXT name="PHASE">PHASE</TEXT>
<TEXT name="PHASEL">L -</TEXT>
<TEXT name="PHASER">- R</TEXT>
<TEXT name="TRIM">TRIM</TEXT>
<TEXT name="DB">dB</TEXT>
<TEXT name="+">+</TEXT>
<TEXT name="-">-</TEXT>
<TEXT name="F">ƒ</TEXT>
<TEXT name="Q">Q</TEXT>
<TEXT name="HPF">HPF</TEXT>
<TEXT name="LPF">LPF</TEXT>
<TEXT name="T">T</TEXT>
<TEXT name="R">R</TEXT>
<TEXT name="EQ">EQ</TEXT>
<TEXT name="DYNAMICS">DYNAMICS</TEXT>
<TEXT name="REVERB">REVERB</TEXT>
- <!-- Legacy Inputs
<TEXT name="BOOST">BOOST</TEXT>
- <!-- Mixes Page
<TEXT name="BALANCE">BAL</TEXT>
<TEXT name="WIDTH">WIDTH</TEXT>
<TEXT name="PAN">PAN</TEXT>
<TEXT name="SOLO">SOLO</TEXT>
<TEXT name="MUTE">MUTE</TEXT>
<TEXT name="SEND">SEND</TEXT>
<TEXT name="RTN">RTN</TEXT>
- <!-- Outputs Page
<TEXT name="VERB SND" platform="MacX">VERB SND</TEXT>
<TEXT name="VERB RTN" platform="MacX">VERB RTN</TEXT>
<TEXT name="VERB SND" platform="Wind">VRB SND</TEXT>
<TEXT name="VERB RTN" platform="Wind">VRB RTN</TEXT>
<TEXT name="TALK">TALK</TEXT>
<TEXT name="LISTEN">LISTEN</TEXT>
<TEXT name="MONITOR">MONITOR</TEXT>
- <!-- Channel Page
<TEXT name="Input">Input</TEXT>
<TEXT name="Inputs">Inputs</TEXT>
<TEXT name="Output">Output</TEXT>
<TEXT name="Outputs">Outputs</TEXT>
<TEXT name="MODE">MODE</TEXT>
<TEXT name="MS">M/S</TEXT>
<TEXT name="SWAP">SWAP L/R</TEXT>
<TEXT name="OVERLOAD">OVERLOAD PROTECTION</TEXT>
<TEXT name="VLIMIT">VLIMIT</TEXT>
<TEXT name="SOFTCLIP">SOFT CLIP</TEXT>
<TEXT name="LOOKAHEAD">LOOKAHEAD</TEXT>
- <!-- EQ Page
<TEXT name="FREQ">FREQ</TEXT>
<TEXT name="GAIN">GAIN</TEXT>
- <!-- Dynamics Page
<TEXT name="IN">IN</TEXT>
<TEXT name="OUT">OUT</TEXT>
<TEXT name="GR">GR</TEXT>
<TEXT name="COMPRESSOR">COMPRESSOR</TEXT>
<TEXT name="THRESHOLD">THRESHOLD</TEXT>
<TEXT name="RATIO">RATIO</TEXT>
<TEXT name="ATTACK">ATTACK</TEXT>
<TEXT name="RELEASE">RELEASE</TEXT>
<TEXT name="PEAK">PEAK</TEXT>
<TEXT name="RMS">RMS</TEXT>
<TEXT name="LEVELER">LEVELER</TEXT>
<TEXT name="LIMIT">LIMIT</TEXT>
<TEXT name="COMP">COMP</TEXT>
<TEXT name="REDUCTION">REDUCTION</TEXT>
<TEXT name="MAKEUP">MAKEUP</TEXT>
<TEXT name="DETECTOR">DETECTOR</TEXT>
- <!-- Meters Page
<TEXT name="FX">- FX -</TEXT>
<TEXT name="PRE">PRE</TEXT>
<TEXT name="POST">POST</TEXT>
<TEXT name="MIC">MIC</TEXT>
<TEXT name="ANALOG">ANALOG</TEXT>
<TEXT name="SPDIF">S/PDIF</TEXT>
<TEXT name="OPTICALA">OPTICAL A</TEXT>
<TEXT name="OPTICALB">OPTICAL B</TEXT>
<TEXT name="MIX">MIX</TEXT>
<TEXT name="MAIN">MAIN</TEXT>
<TEXT name="PHONES" platform="MacX">PHONES</TEXT>
<TEXT name="PHONES" platform="Wind">PHNS</TEXT>
<TEXT name="PHN">PHN</TEXT>
<TEXT name="AES SPDIF PHNS">AES SPDIF PHNS</TEXT>
- <!-- Reverb Page
<TEXT name="PRIMARY CONTROLS">PRIMARY CONTROLS</TEXT>
<TEXT name="TIME">TIME</TEXT>
<TEXT name="PRE-DELAY">PRE-DELAY</TEXT>
<TEXT name="SHELF FILTER">SHELF FILTER</TEXT>
<TEXT name="SHELF">SHELF</TEXT>
<TEXT name="CUT">CUT</TEXT>
<TEXT name="EARLY REFLECTIONS">EARLY REFLECTIONS</TEXT>
<TEXT name="REFLECTIONS">REFLECTIONS</TEXT>
<TEXT name="SIZE">SIZE</TEXT>
<TEXT name="LEVEL">LEVEL</TEXT>
<TEXT name="REVERB DESIGN">REVERB DESIGN</TEXT>
<TEXT name="REVERB TIME">REVERB TIME</TEXT>
<TEXT name="CROSSOVER">CROSSOVER</TEXT>
<TEXT name="LOW">LOW</TEXT>
<TEXT name="MID">MID</TEXT>
<TEXT name="HIGH">HIGH</TEXT>
<TEXT name="SWAPPED">SWAPPED</TEXT>
<TEXT name="SPLIT POINT">SPLIT POINT</TEXT>
- <!-- Reflections Menu
<TEXT name="ROOM A">ROOM A</TEXT>
<TEXT name="ROOM B">ROOM B</TEXT>
<TEXT name="ROOM C">ROOM C</TEXT>
<TEXT name="ROOM D">ROOM D</TEXT>
<TEXT name="ROOM E">ROOM E</TEXT>
- <!-- LCD Glare Overlay
<TEXT name="NotEnoughDSPResources">NOT ENOUGH DSP RESOURCES</TEXT>
<TEXT name="ToEnableThisEffect">TO ENABLE THIS EFFECT</TEXT>
<TEXT name="PleaseDisableOtherChannel">please disable other channel</TEXT>
<TEXT name="EffectsOrDisableOptical">effects or disable optical</TEXT>
<TEXT name="BanksToFreeUpResources">banks to free up resources</TEXT>
<TEXT name="EffectsToFreeUpResources">effects to free up resources</TEXT>
<TEXT name="ReverbNotAvailable">REVERB NOT AVAILABLE</TEXT>
<TEXT name="At2xSampleRates">AT 2x SAMPLE RATES</TEXT>
<TEXT name="EffectsNotAvailable">EFFECTS NOT AVAILABLE</TEXT>
<TEXT name="At4xSampleRates">AT 4x SAMPLE RATES</TEXT>
<TEXT name="ReverbOnlyAvailable">REVERB ONLY AVAILABLE</TEXT>
<TEXT name="At1xSampleRates">AT 1x SAMPLE RATES</TEXT>
- <!-- Legacy LCD
<TEXT name="LCDTrim">Trim: adjust input signal level</TEXT>
<TEXT name="LCDPhase">Phase invert</TEXT>
<TEXT name="LCDPad">Pad: apply 20dB attenuation to input</TEXT>
<TEXT name="LCDBoost">Boost: apply 6dB gain to input</TEXT>
<TEXT name="LCDInputLevel1">Reference: select -10dBV or +4dBu input</TEXT>
<TEXT name="LCDInputLevel2">reference level</TEXT>
<TEXT name="LCDStereoness1">Pairing: mono / stereo operation for</TEXT>
<TEXT name="LCDStereoness2">adjacent inputs</TEXT>
<TEXT name="LCDEnableHWFC1">Hardware Follows Console Stereo Settings must</TEXT>
<TEXT name="LCDEnableHWFC2">be enabled to change this from the console</TEXT>
<TEXT name="LCDSolo">Solo: solo channel to bus output</TEXT>
<TEXT name="LCDMute">Mute: mute channel to bus output</TEXT>
<TEXT name="LCDPan">Pan: pan channel across bus output</TEXT>
<TEXT name="LCDBalance1">Balance: adjust stereo balance between</TEXT>
<TEXT name="LCDBalance2">paired channels</TEXT>
<TEXT name="LCDWidth1">Width: adjust stereo width of</TEXT>
<TEXT name="LCDWidth2">paired channels</TEXT>
<TEXT name="LCDFader">Fader: set channel level to bus output</TEXT>
<TEXT name="LCDBusMute">Bus mute: mute bus output</TEXT>
<TEXT name="LCDBusFader">Bus master fader: set bus output level</TEXT>
<TEXT name="LCDBusSelect">Bus select menu: select bus to edit and view</TEXT>
<TEXT name="LCDBusAssign1">Bus assign: choose an output for the current</TEXT>
<TEXT name="LCDBusAssign2">mix bus</TEXT>
<TEXT name="LCDTalkInput">Talkback input: select an input for talkback</TEXT>
<TEXT name="LCDListenInput">Listenback input: select an input for listenback</TEXT>
<TEXT name="LCDTalkEnable">Talkback button: activate talkback</TEXT>
<TEXT name="LCDTalkLink">Talkback link: link listenback to talkback</TEXT>
<TEXT name="LCDListenEnable">Listenback button: activate listenback</TEXT>
<TEXT name="LCDTalkAtt1">Talkback dim: set attenuation amount for when</TEXT>
<TEXT name="LCDTalkAtt2">talkback is enabled</TEXT>
<TEXT name="LCDListenAtt1">Listenback dim: set attenuation amount for when</TEXT>
<TEXT name="LCDListenAtt2">listenback is enabled</TEXT>
<TEXT name="LCDTalkConfigure1">Output assign: select talkback and listenback</TEXT>
<TEXT name="LCDTalkConfigure2">outputs</TEXT>
<TEXT name="LCDWithShift">With shift: apply to all channels</TEXT>
<TEXT name="LCDWithShiftInputs">With shift: apply to all inputs</TEXT>
<TEXT name="LCDWithShiftInputs1-4">With shift: apply to inputs 1-4</TEXT>
<TEXT name="LCDWithShiftInputs5-8">With shift: apply to inputs 5-8</TEXT>
<TEXT name="LCDWithOption" platform="MacX">With option: apply to all busses</TEXT>
<TEXT name="LCDWithOption" platform="Wind">With alt: apply to all busses</TEXT>
<TEXT name="LCDOptionLockOn" platform="MacX">With option: latch on</TEXT>
<TEXT name="LCDOptionLockOn" platform="Wind">With alt: latch on</TEXT>
<TEXT name="LCDWithCmd" platform="MacX">With command: apply to stereo pair</TEXT>
<TEXT name="LCDWithCmd" platform="Wind">With control: apply to stereo pair</TEXT>
- <!-- DSP Resource Monitor
<TEXT name="DSP">.</TEXT>
- <!-- Monitor Section / Talkback Console
<TEXT name="LINK">LINK</TEXT>
<TEXT name="TalkbackConsole">Talkback Console</TEXT>
<TEXT name="DIM">DIM</TEXT>
- <!-- Monitor Popup Menu
<TEXT name="MainOuts">Main Outs</TEXT>
<TEXT name="Stereo">Stereo</TEXT>
<TEXT name="Quad">Quad</TEXT>
<TEXT name="Custom">Custom</TEXT>
- <!-- Mac Console Error
<TEXT name="No device explanation">Verify that the hardware is switched on and connected.</TEXT>
<TEXT name="No Device Error">No Device Found</TEXT>
- <!-- Mac Core Device
<TEXT name="Not enough bandwidth on Bus.">Not enough bandwidth on Bus. If this is a USB Device it may not be connected to a USB 2.0 Bus. If 1394, then there may be too many devices on the bus</TEXT>
<TEXT name="MOTU CueMix FX">MOTU CueMix FX</TEXT>
<TEXT name="Disabled">Disabled</TEXT>
<TEXT name="Phones 1-2">Phones 1-2</TEXT>
<TEXT name="None">None</TEXT>
<TEXT name="Bus">Bus</TEXT>
- <!-- Win Console Error
<TEXT name="ErrorTitle">MOTU Audio</TEXT>
<TEXT name="DriverNoDevices">No MOTU Audio devices detected.</TEXT>
<TEXT name="DriverNoMemory">The MOTU driver requires more memory</TEXT>
<TEXT name="WrongDriverVersion">Version mismatch. The application can't communicate with the driver.</TEXT>
<TEXT name="InsufficentBandwidth">The device is on a bus that cannot support this transfer rate</TEXT>
<TEXT name="Unknown">An undefined error has occurred.</TEXT>
<TEXT name="NoDeviceFeatureError">This application is not compatible with the MOTU 828 or MOTU 896.</TEXT>
<TEXT name="FileError">An error occoured during file operation.</TEXT>
- <!-- Win Core Device
<TEXT name="NoCueMixDevices">No MOTU Audio Devices that support CueMix found</TEXT>
<TEXT name="NoSMPTEDevices">No MOTU Audio Devices that support SMPTE found</TEXT>
- <!-- Required
<TEXT name="MBOK">OK</TEXT>
<TEXT name="MBCancel">Cancel</TEXT>
<TEXT name="MBYes">Yes</TEXT>
<TEXT name="MBNo">No</TEXT>
<TEXT name="Font1">Helvetica Neue Bold</TEXT>
<TEXT name="Font2">Helvetica Neue Condensed Bold</TEXT>
</XSET>
</resource_list>
