waterfall on 828 mk3 cuemix
Hello,
I dont find real time fft that says motu cuemix features: http://www.motu.com/products/cuemix-fx/overview.html
Googleling i suspect it's only avaible for traveler mk3.
i don't think realtime fft has an expensive dsp cost. besides, traveller-mk3 has the same dsp than 828-mk3.
¿anybody suspect why isn't available for 828-mk3?
Thanks.
Thanks.
Re: waterfall on 828 mk3 cuemix
install V4HD drivers, it will be available then. motu is just too lazy to release new drivers that include what they advertise for their products.
unbelievable but true.
They haven't 5 minutes to upload new drivers to motu.com.
thank you very much for information! Now it's works perfectly.
I think V4HD drivers have some problem. All seems to work very well until you try to open the audio interface inside some host. (The hardware advanced setting inside the ASIO control panel of every host). I tried with Ableton 7.0.3 and Energy XT 2.07 and clicking over the icon nothing happen. Reinstalling the 1.6.8.1960 all restart to work properly. Could you confirm this beaviour?
The same is happen in Cubase 4.5, but I set parameteres in Audio Console (from Windows Start > Programs > MOTU menu) and my 828mk3 works correctly with Cubase.
Hello, yes, with the V4HD, it will work BUT the latence in your software will be not very good, depend what you want to do with. I think i can't go down than 128....with the old drivers on the 828 mk3 installation cd, it can be down to 32...
Strange things....so wait and see...one day..
Sam.
Sam.
My signaling was exclusively related to the behavior of MOTU audio interface setting called by the ASIO panel in every host. I confirm, I don’t encountered problems of latency or drop and glitch with this drivers. Yes it is true the buffer dimension can’t go very low and sure can’t go so low as the precedent release were we can reach 64 and now not less than 128. I hope this limit do not increase more in the future because until now has just doubled at every release.
No. I only noticed this issue: I’m not able to open the MOTU audio interface setting inside an host, I must close the host open the audio interface change some parameter close the audio interface and reopen the host. And… this happen also with the latest driver released yesterday. I think this is the last bug of MOTU…for the moment.
Hmm.... after installing latest drivers (3.6.8.1394) in Cubase 4.5 everything works OK.
I am able to open MOTU Audio Console inside the host and set parameters.
Maybe there is a problem with other DAWs?
