V-Rack Question
- angelvonfrankim
V-Rack Question
I have been setting up projects with V-Racks, and it is a very cool way to get uniform mixes across an entire project as well as save a lot of time.
My question is this: Does anyone know how to set up windows so that you can see the V-Rack at the same time as the mixing board? It would be helpful.
Just Frank,
Dual 2.5 GHz PowerPC G5, 2.5 GB SDRAM, Tiger 10.4.11, DP 6.01, 2408, 896, LiquidMix, Waves Platinum, AutoTune 5
- musicarteca
Re: V-Rack Question
On the upper menu of the console you can switch between sequences, one of them is the V-Rack.
- Shooshie
Re: V-Rack Question
angelvonfrankim wrote:I have been setting up projects with V-Racks, and it is a very cool way to get uniform mixes across an entire project as well as save a lot of time.
I don't know of a way to do that. You have to toggle between them. What is it... Command-Shift-V? Command-Option-V? Not in front of DP, and suddenly I'm not sure!
Alex is right about the Chunks Window being an easy way to toggle them.
- Dwetmaster
Re: V-Rack Question
EDIT:
I take back what I said, It CANNOT be done
Re: V-Rack Question
Unfortunately it's not possible. V-Racks are visible only in the Mixing Board, and there's currently no way to have multiple Mixing Board windows open.angelvonfrankim wrote:Does anyone know how to set up windows so that you can see the V-Rack at the same time as the mixing board? It would be helpful.
- Shooshie
Re: V-Rack Question
carrythebanner wrote:Unfortunately it's not possible. V-Racks are visible only in the Mixing Board, and there's currently no way to have multiple Mixing Board windows open.angelvonfrankim wrote:Does anyone know how to set up windows so that you can see the V-Rack at the same time as the mixing board? It would be helpful.
_______________________
Funny... suddenly your sig line makes perfect sense.
