HELP !!?!!! please ( I have 9 gigs of memory, that should be enough) I have an important recording session today and I can't even open my project
I get this if I try to open over a network drive- have to copy file to local drive first now... PIAmonkey man wrote:
Will the project load when copied to another location? Another drive?
I have the same problem, but I can't find that setting anywhere in dp 6. Can you tell me exactly where it is?scottg wrote:It;s the plugin pre-rendering!! I found turning that off in the DP6 preferences>Audio plugins works..
Glad they tested that before releasing it,,, good going MOTU!
I'm' weighing responses like in in switching from Logic to DP.scottg wrote:DP6 menu,,, PREFERENCES>AUDIO PLUG-INS.. Easy to find.. Turn that crap off they obviously did NOT test well and you should be good to go!
I wish they would test their software before releasing it! I mean, if it's not gonna work on my brand new right outta the box MacPro 8-core with 10gb RAM,,, it ain't gonna work for anyone!
I am seriously considering switching to Logic after 10 years and many professional albums done... Sad,, just sad..
jessrho wrote:hey thanks for the responses good people. i ended up calling motu and they helped me work around it. i had to open a new project and then load the chunk from my corrupt/unopenable file. i still got the -108 error message when i loaded the chunk, but then when i pressed ok to the error message the new/old corrupt/unloadable chunk was there under the chunks tab. so i salvaged all my audio files from there and made a whole new project version. whew!
Dan Walsh wrote:So now I got a prob. The file I just saved in the new project is apparently still corrupted even though I had it workin'. I just went to re-open the new one and I'm gettin error 108 again.
I have no idea why....any one got ideas? I'm really not taxing the system at all. 10 audio trax and a couple of verb aux returns and a little bit of automation. Minor volume adjustments and panning.
I'm stumped.....
