Why must I wait for validation of audiounits everytime
Everytime I open the program it runs validation-10 minutes before I can go. I have moved the folder to both preferences folder-same result. Jaguar Dual and Dp4.52
Peace be unto to you
Re: Why must I wait for validation of audiounits everytime
try 'fix permissions' with disk utility(/Applications/Utilities/...)
cause something is not right on your system....
- Timeline
Go to your audio plugins folder and take out all plug demos and invalid plugs then repair permissions on your mac.
Might require you to also trash DP folder in Preferences in the system library folder.
Also, because G5 uses a multiuser setup, you might check for the same thing in your USER folder as it duplicates the System Library folder so that different users can block others from use.
If there are stray plugs there it also could cause the issue.
Hope this helps.
Hope this helps.
no need to delete the whole dp folder in the prefs, just delete the audio unit info cache...
