Hi there folks, My main app is DP but I find myself having to work in PT LE for the next little while. No problems really but I'm wondering if I can hook up the 2408 mk3 to the digi 002 via adat and have the inputs recognized by PT? My goal is to use my outboard digital fx units which are hooked up with my 308, get the signal over to the 2408 via Cuemix and then blast it out the adat port and into the 002.
It looks like I can do this in theory but I wanted to see if I was maybe missing anything before investing in an 002 needlessly. (they don't seem to know on the DUC)
Thanks for any help.
Can I hook up a 2408 to a digi 002?
Michael Telle
Vagabond Music
Vagabond Music
Re: Can I hook up a 2408 to a digi 002?
It'll be a little complex, but yes, you can do exactly what you described. Pro Tools won't be able to use the PCI-424 system directly, but you can use the CueMix Console app to route audio from 308 inputs to 2408mk3 outputs. Just make sure you set the clock source properly for the 002 and the PCI-424 system.
