MOTU 828 MK3 "Flashing LED"...pls help
thabutcha
Post by thabutcha »
Hello.
I turned off my 828 last night to clean some things up in the studio. After I started the 828 up all I'm getting is the main LED screen Flashing and the MOTU audio set-up (ver.driver 1.4.9) not recognizing the unit.
I had a Lacie external drive and a Duende mini on the firewire chain so I removed all of them and tried to reboot with know luck.
I have 5 different FW cables and tried all of those still with know luck.
I searched these forums and I'm surprised that no-one has had a similar issue with the 828 MK3. Ive tried everything including reloading the most recent drivers. I also have the most recent firmware on the device. ver. 1.0.6
My head hurts from trying to resolve this problem. I GIVE UP..
Is there any advice that someone can give me? I feel like I've tried everything.
Has anyone encountered this problem before?
Thanks in advance and HAPPY NEW YEAR.. :)
thabutcha
Re: MOTU MK3 "Flashing LED"...pls help
Post by thabutcha »
Forgot to add....
as I was playing with my FW chain. I isolated the problem to the 828 MK3's FW ports cause anything I put after the 828 is not recognized by my MAC MINI (ver 10.5.6)
bkshepard
Re: MOTU 828 MK3 "Flashing LED"...pls help
Post by bkshepard »
It sounds like the Firewire port has died on your 828. Do a search for "flashing LED" in the forum and you'll find several posts about interfaces having the same problem. It seems to be a common symptom on MOTU interfaces when the FW port goes bad.
-Brian
Mac M1 Ultra 20-core, OS 14.6.1, 128 GB RAM, DP 11.3.2, UA Apollo x6
