Hi Does any genius out there recognize and know what to do about the error message -108 when I try to start up my DP6 ? I'm on a year old Quad Core Zeon with OS 10.5.5. I can't open my project; i get this error message "An error occurred while reading from the disk. The file was not loaded. MacOS error: Ran out of memory (-108)
HELP !!?!!! please
Help!@! Memory Error -108
Re: Help!@! Memory Error -108
also i should add that i have 9 gigs of memory, should be enough right?
if you can help, thank you so so much.
I've been having the same problem recently on a dual quad-core with 9 gb of RAM running DP 6.01. I tried loading the file from a blank project but still no luck. What is your default sound file preference? Mine was bWAV at 24 bit so I returned to good old sound designer files and since then haven't suffered the -108 crash.
