Sync trouble linking 2 828 units
quebone
Post by quebone »
Hi everybody
I had a 828mkII which have always worked fine, and I bought a 828mk3 last week, because I needed to increase my inputs.
They are linked through a FW cable. The mk3 is connected to the laptop computer with another 6-pin to 6-pin FW cable (I have a 2-port FW pcmcia card).
Quite often one of my units gets out of sync. I've tried setting either the mkII or the mk3 as internal clock, but with no better results.
I have connected them via a BNC cable, having the same problem.
I have the last drivers installed (3.6.8.1328).
Anybody has a suggestion? I've tried everything but the problem presists.
Thanks.
TheRealRoach
Re: Sync trouble linking 2 828 units
Post by TheRealRoach »
It''s a pain in the neck problem and very common for windows users. Read this:
http://www.motunation.com/forum/viewtop ... 14&t=31518
Mike Rocha
http://www.mikerocha.ca
Custom ADK, Quad 3.0ghz, 4gig ram, Win7 64-bit, Motu 3.6.7.3 x64 drivers
Macbook Pro 13" touchbar, High Sierra, 73220 drivers
Motu 896 x 4
quebone
Post by quebone »
Thanks, TheRealRoach,
By now it seems that with Nuendo 3 it works OK. But I keep having lots of sync problems when working with SAWStudio.
TheRealRoach
quebone wrote:Thanks, TheRealRoach,
You're gonna have to give a little more detail than that. Did you try the "fix" that I posted? Are the sync problem symptoms in SAW the same as those
characterized in my linked thread? Also, you should post your systems specs, OS, and software versions.
Mike Rocha
Motu 896 x 4
