so i will have between 200-500 dialogue files that will need to be cleaned up a bit, etc, and then bounced out of DP.
howdo i bounce out all of these files?
would i use export selected bites?
i cant just bounce the audio track as a whole because i would have to go back in and re-edit all of the dialogue into single files again.
Batch bounce or batch export?
Kung Fu!
Re: Batch bounce or batch export?
Hey Chagos, if you "export selected bites", DP renders the various references your soundbites make to the original audio file as new ones, so IMHO this would be the way to go.
so would the inserted effects i add to the dialogue be rendered if i did it this way as well?
Kung Fu!
No Cagos - you'd have to either bounce or mix them down first (play 'em and bus them to new, record-enabled tracks), or apply the processes in non-realtime from the region menu first. The export option simply renders your defined regions (soundbites) along with their fades.
yeah thats what i thought. oh well, bussing shouldn't be a problem. i'm just happy dp has a batch option!
Kung Fu!
Yup, it's best to be grateful for what we have. Happy bussing, man.
