+1 on the RAMmagicd wrote:...once or twice a year, I run into a customer who has "bad RAM" in their computer. The RAM passes basic hardware tests, but the computer is just not stable. The only way to really isolate bad RAM is to remove it from the computer. I notice one user mentions 18gb of installed RAM. Under OSX, that much RAM is not helping anything, but you certainly have the opportunity to remove all but 2gb and see if stability improves. If not, swap that 2gb out for a different set of RAM sticks and compare.
Dave
magicd@motu.com
I had this problem on my now (largely retired) dual G5. I spent days and days installing and uninstalling apps, plugs, etc. to try to get 'DP' stable, when in the end, it was my bloody after market RAM all along. I finally broke down and got a tech out to look @ my box, and he happened to have some extra DIMMS with him. After explaining my problems and trouble shooting to him, he nodded wisely and reached into his kit bag, pulled out the DIMMS, swapped all of mine out, and voila! problem solved.
Since then, I have set up DP on my new, clean machine (Intel) and I thrash/test it after every new plug (or even other app is installed). Every now and again, I find something that makes my DP unhappy, and when I do, the naughty new toy gets sent to the sin-bin until I can google up a fix.
I have come to the conclusion that the complex dance of interactions with plugs, OS's, apps, hardware etc. can only be approached scientifically and incrementally - start with a clean machine, do a clean OS install, put DP on the machine, test. Add something, test. Add something else, test. When you hit a problem, roll back, and test. Its a pain, but at least now I can run a DP session without bursting a blood vessel every 5 minutes when it crashes.
Right now, I am trying to get the new PodFarm plug to work in DP 6.01. It doesn't, so its in the sin-bin. When Line6 can figure out the problem, it will go back into my DP eco-system, until then, it is banished from my little garden of Eden.
