will 4.6 work under 10.2.8?
jerkrecords
Post by jerkrecords »
yes yes - we're using 4.5 on 10.2.8 still. it's always worked fine, so never bothered to mess with a good thing.
however...
this new 4.6 is way too tempting. any reason why i shouldn;t attempt the upgrade?
thanks people.
pete
http://submergentrecording.blogspot.com/
computer setup:
dual 2Ghz PPC G5 w/ 3gb ram / 10.4.11 / DP4.61/ DP7 / DSP Quattro 3.1.1 / 2xUAD-1 (v5.4.0) / URS / Stillwell / Audio Damage / Waves V5.0 / 2408mkII / PCI424 / 2xRME ADI-8 Pro / Ultralite
Morpheo
Re: will 4.6 work under 10.2.8?
Post by Morpheo »
Nope, 10.3 is the minimum...
Mac Pro 5,1 12-core 2.4 GHz//40GB RAM//RX 560//macOS 10.13.6//SSDs//MOTU 896//Keylab 88//Faderport 8
Pro Tools 2018.7//LPX 10.4.1//DP 9.51
NI Komplete Ultimate 11//Albion One//Soundiron Choirs//Pianoteq//Analog Lab//VSL SE & Chamber Strings//etc
Paradox
Post by Paradox »
Yes, DP 4.6 will work on 10.2. However, 10.3 is the minimum _supported_ configuration, so don't expect tech support to help you if you have problems.
