List of plugins DP6 doesn't like
Eleventh Hour Sound
Re: List of plugins DP6 doesn't like
Post by Eleventh Hour Sound »
David Polich wrote:Melodyne not working is a total deal killer for me. I rely on it heavily at
the moment, working with a singer who, shall we say, is "all over the place"
vocally, and that's a charitable comment.
Have you tried using the plug in version with Always run in real-time selected? I think I had it working the other day. For pitch stuff, I've mostly been using DP built in pitch editing. It's quick and easy :)
DP11.1, 16" MacBookPro 2.3Ghz 8 Core i9's 32GB Ram 1TB SSD, (2) external 1TB Samsung SSD's , Steven Slate SSD 5.5 and Trigger Drums, ML-1 Mic and VSX Headphones, Omnisphere 2, Trilian, Ivory2, EW, MSI, MX-4, Philharmonik 2, Komplete, Reason, Live, Melodyne, IK Multi's Total Studio, ARC, T-RackS, SampleTron, AMG's KickA--Brass. and my beloved guitars :-)
Eleventh Hour Sound
nhmorgan01 wrote:Mentioned this in another post, but probably is more suited here:
T-Racks (1.22 and 1.3)
If try to apply it to a soundbite (not use it as an insert on a track), none of the parameters can change while previewing the audio. Knobs and switches just sit stubbornly in place. Once I stop preview, everything's fine, but that just means a lot of trial and error if I can't hear the changes real time.
1.22 is dust, but 1.3 works great as an insert. They're coming out with version 3 next month. That should work :)
myownmus
Post by myownmus »
Since my upgrade a week or so ago to DP 6.0.1 cannot get any of my East West Plugins to work? They all load, but when you attempt to select an instrument in the player,it becomes a blank effects window or portions of the player turns" white" and unusable. This is true whether I am using the new "Play Version" or the older Kontakt or Kompakt Player, all of which worked just fine in DP 4.6.1. Do any of you know whether such a problem existed in DP 5? East West does not know what the problem can be either. I depend on these virtual sounds, so am sort of "shipwrecked" at the moment!
Eleventh Hour Sound
myownmus wrote:Since my upgrade a week or so ago to DP 6.0.1 cannot get any of my East West Plugins to work? They all load, but when you attempt to select an instrument in the player,it becomes a blank effects window or portions of the player turns" white" and unusable. This is true whether I am using the new "Play Version" or the older Kontakt or Kompakt Player, all of which worked just fine in DP 4.6.1. Do any of you know whether such a problem existed in DP 5? East West does not know what the problem can be either. I depend on these virtual sounds, so am sort of "shipwrecked" at the moment!
Which version of Kontakt are you using? I upgraded to version 3 and that fixed my Kontakt issue. If you list your equipment and software versions in your signature it's easier to help you.
myownmus
Post by myownmus »
I am using Mac OS 10.4.11 on a Dual 2.7 GHz Power PC G5, 4. 5 GB RAM , DP 6.0.1, Kontakt Player 2.2.4, East West Play 1.0.083, EWQL Gold Symphonic Orchestra 1.0.44, Gypsy 1.0.028. None of these Native Instruments Plug-ins work, though they all load when I start up DP.
beautypill
Post by beautypill »
Anyone heard from Soundtoys.
I'm having a nightmare with the knobs for Crystallizer. It's so frustrating.
Have they acknowledged the problem? Or is it one of those lovely two-companies-pointing-fingers-at-each-other scenarios between MOTU and Soundtoys?
- c
mjc
Post by mjc »
POD Farm and TC Powercore AUs both show the same behaviour - the GUI for the plugin is frozen, but the plugin still processes the audio. With TC, I can change presets (and hear the audio processing change) but with POD Farm it's stuck on the default preset. POD Gearbox plugin works fine.
DP6 seems oblivious to the AU shenanigans and works away happily.
AudioDesk reported that POD farm passed vaildation, but may degrade performance the ran the plugin just fine. No probs with Powercore.
Garageband and Logic Pro 8 are quite happy with both POD farm and TC Powercore.
Mike
Mac Pro 2 x 2.4Ghz Quad Core, 14GB RAM, OSX 10.10.4, DP9.0 MachFive3, BFD3, Logic Pro X, 828MkII1, MTP AV, Mackie MC, A&H Zed 16R, POD X3 Korg SG pro X, 2 many guitars & amps
Harry
Post by Harry »
All Native Instruments VI's don't work with DP 6.01 and OS 10.5.5.
OS 10.14.6, iMac i7.3,5 with 32 GB Ram, 828x, Miditimepiece AV, DP 10.00 (ger.)
MachFive 3, MSi, Ethno 1, Omnisphere 2, Sampletank 4, Forest Kingdom II, Desert Winds, EWQLSO-Silver, Real Guitar 2, VLP120, PLP120, VCP120, Liquid Saxophones, Elastic, The Resource, Wave Arts PowerSuite 4+5 and Master Restoration, Kontaktplayer, Absynth 5, Ni Action Strings etc.
jwfatgruv
Post by jwfatgruv »
Harry wrote:All Native Instruments VI's don't work with DP 6.01 and OS 10.5.5.
From my recent experience (the last three weeks) this is not true. Komplete5/Kore2 bundle works fine with DP6.01 under 10.5.5. Including using the Kore2 control surface.
All the best,
Jim
BKK-OZ
Post by BKK-OZ »
I've said it before here, this is wrong. I am happily using Absynth 4+ on an Intel mac with 6.01 & 10.5.5.
Just because you are having a problem :( doesn't mean that everyone is.
Cheers,
BK
- M Kaku
Patently false! This is why I regret reporting things here sometimes because this sort of hyperbole gets spread around. Firstly, some NI VIs don't work with PPC processors and DP 6.01 and OS 10.5.5. Some. But if you're on Intel most of them work find as far as I know. This sort of statement is very irresponsible and of course just plain wrong.
chaim
Post by chaim »
dix wrote:DP 6.01 doesn't seem to like Auto-Tune 5. Was getting crashes w and w/o pre-rendering on. Eventually the file would crash on Open. I had to remove AT5 from Components. I upgraded to Version 6 (Evo). So far so good.
You are most likely using Auto Tune Evo in an insert. Try to apply it to a soundbite please, and let us know. (save first :D )
I'm on PPC OS 10.5.5 and DP 6.0.1 and Evo works fine as an insert but crashes when applied to a sound bite.
But that's not only AT6. It's with all Audio Units I use. (waves, PSP, T-racks, sound soap, and apple) They all don't work in preview/apply mode.
Using the MAS audio Unit Bundle version 1.7.
They do work with version 1.6.1. But then Kontakt 3 wouldn't work.
Mac Pro 2X quad core 2.26 Ghz, 22 GB RAM, OS 10.8.4 | DP 8.05 | 2408MKII
Beta Tester for Toontrack
SixStringGeek
Post by SixStringGeek »
Maybe on PPC, I can't say. I have B4 II, K3, Absynth, all working great on DP 6.01 and OS 10.5.5 on intel.
In fact, I've just retested all my plugs while doing a reinstall on a Macbook after disk failure and I do not have a single problem with anything listed in my signature on DP6.01 and 10.5.5 on intel.
