Hey all,
Has anyone else encountered this issue with DP 6.01? I just upgraded from 5.12 and noticed it as I tried to master my first mix.
If I select a audio chunk (usually my full mix) and open up T-Racks to do a quick master, T-Racks won't let me change any settings while I'm previewing the mix; the knobs all just stay locked in place. Once I stop the preview, everything works fine, but if I can't hear the changes as I make them then I'm kinda flying blind to a degree. I was running T-Racks 1.22, then upgraded to 1.3 to see if it would solve the problem, but no luck.
Anyone else experience this? Solutions?
Thanks.
-Nate
T-Racks and DP 6.01
T-Racks and DP 6.01
2.66 Ghz 12 core Mac Pro, 32 GB Ram, OSX 10.6.6
Re: T-Racks and DP 6.01
do you mean using T-Rack as an audio suite?
if so , most of my audio suite plug won't change their parameters while previewing.
This is the reason I'm not using DP6.
The post processing, I do with-in AudioFinder, handy.
http://www.spoonwood.net
http://www.davidgennaro.com
2.16 Intel Core 2 Duo, 10.4.11, 3gigs ram, Ultralite 2 (good Box),Bunch of FireWire Drives, guitars guitars guitars, plugins plugins , mostly use Kontakt3
- Eleventh Hour Sound
I'm using T-RackS 1.3 as an audio unit plug in inserted in an audio channel in DP 6.01 and OS X 10.5.5 and it works fine. When I upgraded to 1.3 I later found out that it left the old 1.22 in place and it's easy to accidently use it, and yes it not only freezes but can cause some crashes too. Make sure you select T-RackS 1.x rather than the plain T-Racks S. (I don't remember the exact spelling, but 1.3 will be listed as 1.x.nhmorgan01 wrote:Hey all,
Thanks.
-Nate
DP11.1, 16" MacBookPro 2.3Ghz 8 Core i9's 32GB Ram 1TB SSD, (2) external 1TB Samsung SSD's , Steven Slate SSD 5.5 and Trigger Drums, ML-1 Mic and VSX Headphones, Omnisphere 2, Trilian, Ivory2, EW, MSI, MX-4, Philharmonik 2, Komplete, Reason, Live, Melodyne, IK Multi's Total Studio, ARC, T-RackS, SampleTron, AMG's KickA--Brass. and my beloved guitars
dogBoy wrote:do you mean using T-Rack as an audio suite?
Yeah, not using it as an insert like the other poster suggested. Weird bug... I guess it just means having to take an extra step by using it as an insert and re-bouncing.
