stylus rmx won't work in v-racks
peteruno
Post by peteruno »
So happy to see multiple qt movies and v-racks as I usually work on a show that has 5 acts which I used to have to make 5 separate files for in order to hold different quicktime movies. Got all the different movies into 5 separate chunks okay but now I'm setting up the v-racks and so far got Mach 5 to work but spectrasonics RMX wont open- anybody got it working?
OS 10.4.8/DP5.11/MacbookPro/2gig ram/G5 dual 1.8/4 gig ram (10.3.9)/Kontakt2,Stylus RMX,Native Instruments,Pluggo,Altiverb, fw 800 drives, Yamaha 01V,01X,02R,etc...
dtobocman
Re: stylus rmx won't work in v-racks
Post by dtobocman »
I'm cruising with Stylus and V-Racks.
I think I've got your fix... when you add a Stylus track, the default output in the V-Rack may not be something active. Make sure you've got the output on the Stylus channel set to something active.
I think I had a big swearing session over this issue when I first installed... Hope I helped you.
David Tobocman
www.DavidTobocman.com
thracks
Post by thracks »
Chiming in........ Stylus RMX+ V-Racks=good here.
Steve
2020 Mac Mini | Sonoma | 828x |
