My DP 6.01 has been starting up pretty slow...As soon as the project opens and all windows pop up, all the faders go to maximum height and hang there for about a minute with the mac "spinning ball of death" and then I am able to playback the project. Is this normal or should the project open and be imediately available to play??? DP 6.01/Waves SSL Bndle/MacPro 3.0Ghz Quad/6 Gig Ram/Mac 10.5.5
I can't remember when this started, but just wondering if this is normal???
Tim
Slow DP Startup anyone?
http://www.timothyclee.com
MacbookPro-MacPro-Mico Express-DP 7.02
896HD x 2
8pre x 3
UAD Neve Bundle
SSL SSL Bundle
Kontakt 3
Ozone 4
896HD x 2
8pre x 3
UAD Neve Bundle
SSL SSL Bundle
Kontakt 3
Ozone 4
Re: Slow DP Startup anyone?
Trashing DP prefs should be mandatory after or before installing 6.0.1 - this version requires it more than any version I can remember in the past.
Larry
Larry
DP 9.12, OS 10.11.6, mac pro 8 core, 24 gigs ram, Mach Five 3.2, MSI, Superior Drummer, Battery, Reason, Slate Drums, EW Gold
http://www.2ndstprod.com
http://www.dannysguitarshop.tv
- timriley
DP5.13 is quite slow to start up sometimes when im opening projects that use VIs.. Still, i'm only talking 5, 10 or at worst 15 seconds here.. A minute seems like alot!
For clean projects startup is almost instant...
Should be the same in DP6, I would of thought.
Mac Pro Quad XEON/2.8Ghz/12GB RAM
Macbook Pro Core Duo/2.16Ghz/2GB RAM
OSX 10.6.8/DP7.22
OSX 10.6.8/DP7.22
DP 5.13 takes a very long time to start up when opening up older pre-DP5 projects, in my experience. At least three minutes on my setup.
Are you talking about opening old projects or starting a new one?
PPC Dual 2.3Ghz, 4.5 GB RAM, OSX 10.4.11, DP 5.13, 828 MKII, MIDI Timepiece USB AV, 2nd internal drive for audio, Liquid Mix, Waves, Blue Tubes, MH Channel Strip, PSP, Audio Damage, Ozone 3, T-Racks, NI, Spectrasonics, Arturia, a bunch of VI's running on a PC.
http://www.davepolich.com
