I previously had an Edirol FA-101 which worked fine with my laptop while recording 8 tracks simultaneously and playing back 24, blah blah blah...
Obviously I'm quite disappointed that a supposed high-end unit I purchased as an upgrade is giving me serious problems where an entry level unit worked fine.
Nitty gritty details...
- Yes, I am using Vista (32 bit, visual effects turned off, etc)
- The NC8430 has a TI firewire chipset
- I'm using a Belkin 4-pin/6-pin cable
- I have a Behringer ADA8000 hooked up through ADAT, with the ADAT out of the Motu connected for sync but disabled for actual output
- Recording just a few empty tracks from different inputs at 44.1k/24bit gives me constant clicks that appear in the recordings
- With my FA-101 I could record 8 tracks at 96k with only some slowdown which didn't manifest into any problems with the recordings
- When I mute, solo and unmute tracks during playback, Vegas hangs for a few seconds while high-pitched squeals come through the outputs
- I also get other pops and stuff while opening programs that use the device
- The clicks occur every few seconds and register on the output meters
- When I plug it into my main computer (also Vista) using a 6-pin cable, everything is fine. I can record 16 channels with no problems.
I've considered racking up my main PC but that's really not an option at the moment. How do you think would an old AMD 2500+ machine hold up against a Core Duo laptop?
I need this laptop up and running for recording again by next week (and before I get some smirky "buy a MBP response", I have no money and no wish to buy into Apple products).
Help me, please!
Matt
