The vertical zoom in tracks overview might alleviate some of that.e-snobben wrote:I don't like it, F. I feel lost, especially in the counter window.I think they should have left it alone. Too small fonts makes it difficult to read.
DP 6 GUI - What do you think of it?
Re: DP 6 GUI - What do you think of it?
Having given fonts a thought I agree with you about the size, they're probably the same. But they appear smaller to me, maybe due to the lack of graphics surrounding them.screensound wrote:No problem here with small font. It is equally as bad as DP5.
Windows 11, DP 11
https://www.youtube.com/channel/UCOI37x ... 8vAQJwNm_A
Yeah, that's an improvement (thanks MOTU). I was more referring to the counter GUI in this case, sorry about the mix-up. And, as mentioned in the previous post, the smallness of the fonts may depend on that.James Steele wrote:The vertical zoom in tracks overview might alleviate some of that.e-snobben wrote:I don't like it, F. I feel lost, especially in the counter window.I think they should have left it alone. Too small fonts makes it difficult to read.
Windows 11, DP 11
There's gotta be a font file in that app. maybe compiled though. But if you could find it, you could switch it out for anything you wanted: Zapf Dingbats even.
Success is just one more plugin away! And happiness is as close as your next upgrade.
Found quite a few issues with the new GUI and I've only been using it for about an hour
My biggest UI issue is with the mixer so far ... I can no longer read the full I/O names in the mixer board ... they have taken away even more of what little space there was in there with the little arrows (which IMHO are not needed). All of my interface I/O's look like TDI... 1-2, ugg. I dread going through and renaming them all as I don't know how older projects are going to handle this and I really really don't want to have to go through a hundred projects and re-select all my I/O outputs if it doesn't handle things well.
Has anyone tried this? Am I asking for trouble here or should I deal with the fact that I'll have to physically click on each channel strip to see where it's going every time
I do some pretty large projects here ... the one that is open has about 126 tracks right now.
15" Macbook Pro Retina quad 2.5Ghz 16G/512G SSD (2015 model),
Raven MTi2, 4k Vizio TV, Pegasus TB2 RAID5 (6TB),
UAD TB Apollo Twin Duo, UAD TB Satellite Octo, Tascam DM-3200/IFFW-DMII
DP 9.0.2 (Pro Tools 12.4, Logic Pro X 10.2.2), OS X 10.10.5
The blinding white light of DP6 leaves a purple spot after staring at the screen for hours, Amplidood's GUI MODS are a must for anyone who stares at DP6 for more then a few hours at a time.
I still like DP5 best, Less buttons in DP6 control.
Just installed DP6 and I have to say that fonts in six are somehow ugly, hard to read. I don't like the new mixer window either. Otherwise DP6 rocks!
PTHDN(TB)/OMNI / DP8 ** Post Production **
Unfortunate news, Gerkster (may I call you Gerkster? I like the sound of it). I spent a great deal of time tweaking all my send buss, track, aux channel, mixer and even MIDI destination names a while back so that they were all eminently legible in the TO and mixer. Bummer. I agree that when space is at a premium, such as is the case with the narrow mixer view, little arrow thingies are hardly necessary or justifiable, IMHO of course.Gerk wrote:My biggest UI issue is with the mixer so far ... I can no longer read the full I/O names in the mixer board ... they have taken away even more of what little space there was in there with the little arrows (which IMHO are not needed).
I've tried it out for a couple of hours now. And as a matter of fact, I feel lost in most areas. It seems as if the major news in DP6 is actually the GUI. I'm just sitting here, staring at the windows, paralyzed, fumbling in the darkness.e-snobben wrote:I don't like it, F. I feel lost, especially in the counter window.I think they should have left it alone. Too small fonts makes it difficult to read.
* Bad Mixing Window!
Others have said just about what I would say. I shall not spend time trying to find the right words and expressions.
* Bad Consolidated Window!
No easy way to get another window row as in DP5 where you just grab the handle at the top. Do one always have to doubleclick the free space and then snap it into the CW? That is if it hasn't been there before of course. I've search a lot in the manual, maybe my tiredness was the cause of failure. But this tiredness arose from the strenuous task which is called DP6.
In DP6, you grab the handle at the bottom.e-snobben wrote:No easy way to get another window row as in DP5 where you just grab the handle at the top.
MacBook Pro retina 2015, i7, 16GB, DP 10, M4
Thanks!b.g. wrote:In DP6, you grab the handle at the bottom.e-snobben wrote:No easy way to get another window row as in DP5 where you just grab the handle at the top.
I don't want to jump to conclusions, but this may acually be an improvent.
Windows 11, DP 11
I wish you could open up the hardware preferences on the main screen instead of having to open it up in the studio settings.
I also miss the big zoom buttons on the upper left-hand corner of the sequence editor.
I'll be attempting my first real mix session tonight or tomorrow with DP 6, so that will be the true test. I skipped DP 5, however - I went straight from 4.61 to 6, due to my spankin' new Mac Pro.
So far, I think the GUI's an improvement, although I find myself fishing for the manual somewhat frequently (although that's usually the case with an upgrade). I do think MOTU could stand to back off the major GUI redesign for a while now.
Maybe I'll come back with a rant after my mix session.
anybody know how to set your parameters- in the past you could just use the "." in the 10 key to tab you from one numeric value when setting region parameters in the tracks window when you are editing.
Seems now it will not jump to the numbers on the end of the region- you actually have to use the mouse to change to the ending parameters after you have set the beginning values. anybody figure out how to get around this change??
MOTU user since 1988
Tree Roots 32 ch Console, StamChilds, Zenner, Pultecs, StaLevel, Neve racks, SSL, WesAudio & Stam racks, Burl Mothership, Barefoot MM27, AMS reverb, Mac Pro, UAD, Waves, Lexicon-
