DP 6 and East West Play engine
michael77
Post by michael77 »
Is anyone out there running DP 6 with the new East West Play engine? ( Platinum Plus)
I'm having small issues, but enough to make tracking and mixing strings very difficult.
Frodo
Re: DP 6 and East West Play engine
Post by Frodo »
What specific troubles are you having? PLAY is among the few VIs I have running in DP6.01 that actually works.
303creative
Post by 303creative »
I, too, run the Play engine with Ministry of Rock, and it seems to work fine. But sometimes it keeps on having to re-load the samples if I leave the play tracks dormant for a while. If this is a clever way of saving processing power that DP6 has come up with - then great, but its a bit annoying each time it happens.
michael77
Post by michael77 »
I'm using East West orch. Platinum Plus library.
It does have too re load the samples quite a bit which is annoying
but also in the MIDI edit window the notes won't respond when you
select them separately. Therefore when editing a string part in EWQLO
you can't hear the pitches that you're trying to edit. Frustrating.
Frodo
Post by Frodo »
Are you running SO with pre-render active? There's a certain workflow "normalcy" when it's set to real time.
