Amplidood's GUI mod 3.5.2 (always updating first post)
Re: Amplidood's GUI mod 2.6.2 (always updating first post)
Really, really beautiful.
I do also prefer the new pan knobs.
The track window is so pleasant, now.
MacPro 2.66 - 8Go ram-10.6.2 /DP7.2/URS plugs/Kontakt4/PlugsoundPro/StylusRMX/EZDrummer/Superior/Altiverb/Ozone4/Sonnox/etc...Neve 8801/RME ffce 800
- Dwetmaster
Hey dood
Did you notice that the markers' name background in the SE don't match the ruler's background? Do you know where the setting is for that?
Added a list of conundrums I can't get around...first post, of course...
deleted
Not sure... you don't suppose adding a small area of the color that matches the mixing board background to the right side of the buttons in the button graphic PNG might somehow cover it?amplidood wrote:I can't figure out how to get rid of the white space that's still left after deleting the button text from the Localizable.xml file.
The text is a layer above everything else. It's somewhere else in DP's code that I can't seem to find.James Steele wrote:Not sure... you don't suppose adding a small area of the color that matches the mixing board background to the right side of the buttons in the button graphic PNG might somehow cover it?amplidood wrote:I can't figure out how to get rid of the white space that's still left after deleting the button text from the Localizable.xml file.
Hmmm bummer... I got nothing.amplidood wrote:The text is a layer above everything else. It's somewhere else in DP's code that I can't seem to find.James Steele wrote:Not sure... you don't suppose adding a small area of the color that matches the mixing board background to the right side of the buttons in the button graphic PNG might somehow cover it?amplidood wrote:I can't figure out how to get rid of the white space that's still left after deleting the button text from the Localizable.xml file.
Can you do one in pink?
Chuckle, chuckle.bzfoto wrote:Can you do one in pink?
New alternate mixer buttons...for light version. I feel bad, I've been leaving the dark version behind a bit.
Just wondering if you can make the graphic of the buttons wider - it might cover the white space?
Gonna add a note to the first post...
The words for the buttons are in a layer above all other graphics in the Mixer. I dont' know where this is controlled.
Narrow view could use some separation lines in mixer?
My favorite so far was 2.2.1 but 2.6.2 looks amazing too.
I am using bits and pieces of 2.6.2, but not the whole thing. I am fishing for a couple of specific tweaks within the mod files that I can't seem to locate:
Which file is responsible for changing the fader level meter color from blue to green? I was actually trying to keep the stock DP6 fader knobs, but just change the meters back to green.
Is there a file that will change the color of the consolidated window background? I have applied the "dark" mixer background, but would like to change the consolidated window "tray" background behind the mixer.
Rick
Rick
I have to admit I've been kinda ignoring the whole Consolidated Windwo thing because i never use it. I will look into this.
