Ultralite mk3 Outs
Ultralite mk3 Outs
Is it possible to route the audio from a computer to more than just the Main Out 1-2 at the same time?
I want to send the same signal to a speaker system and to the front of house.
Can't find anything in the manual.
I'm using Mainstage (Logic Pro) BTW for live performances.
Thanks,
J M
Thanks,
J M
Re: Ultralite mk3 Outs
The ULmk3 has a feature where the main outputs can mirror any other output pair. So you can configure the playback software you're using to output to analog 1-2, for instance, and then set Main Out Assign to analog 1-2. Now the same audio signal appears at both output pairs.
Thanks, that's great. Obviously I'm still getting my head around the Ultralite.
It's a great little box.
J M
J M
Can the original Ultralite do this? If so where does that get set/
Thanks-
D -
Thanks-
D -
No, unfortunately the original UL doesn't have this feature.OortNYC wrote:Can the original Ultralite do this? If so where does that get set/
Thanks-
D -
- therealbigd
any motu hardware with more than 1 set of analogue outs should be able to perform this. use the "Motu Audio Setup" menu (microphone icon)
Just remember kiddies, You can't polish a turd.
Macbook Pro 2.4GHz 15" i5 + MBP 2.4 15" C2D, MOTU 828mkII FW (Logic 9), Wilson Benesch Arcs + Cyrus Amps; PMC DB1S+ & MC2 Amps; REL Acoustics Strata 5 Sub.
this was driving me nuts. stupidly complicated and poorly documented. here's a step by step that will help.
http://www.merges.net/miscellaneous/motuUltraLite.html
