nadeama wrote:
Michkhol,
Thank you for running the test and confirming that I'm not totally insane by reproducing the MIDI bombs! The volume outburst is indeed more difficult to reproduce. I have seen it in this same sequence but it happens less often, and today I was able to reproduce it only once in several minutes of testing. So it's not too surprising that you didn't experience it.
If my guess is correct then audio bursts are more likely with faster processors with multiple cores. If synchronization does not use standard (albeit costly) means, it is very easy to miss something. It works on slower machines just because timing happens to be right.
As for the MIDI bombs, I'm not 100% certain, but I think it can also happen even if you press stop before rewinding. I should really try this again to make sure, but I'm 99% certain that this has happened in my testing.
Sorry, I was not clear the first time. I didn't test the "stop-rewind" sequence. I hit stop when the MIDI was choking (no MIDI activity, no audio) and after that the playback was normal again. This actually gave me the idea that "stop" command surely resets the internal buffers, but there is something wrong with instant rewind-and-play thing.
Thank you for the explanation on what may be happening. I can't honestly say that I understand every single detail, but I get the general idea. It seems like it might indeed be a nightmare to fix for the poor engineers.
If the design was right from the very beginning (and it is very doable, look at Logic for example), they would not have this nightmare in the first place.
What's interesting is that at some point the design was right, because I've never had those problems in DP 4.61. I tried the same test sequence on the same computer, with the same OS, and DP 4.61 runs it perfectly, while DP 5 exhibits the symptoms. This has to mean that something was changed in DP 5 (and the change maintained in 6). I can't understand how come some people started having these issues in DP 4.x. It makes no sense to me.
This is the perfect illustration of "if it ain't broke, don't fix it". I have a question though (I don't have 4.61). How is the 4.61 audio performance different from 5.xx audio plugin and VI-wise?
Oh and.... for anyone else running the sequence, it's atonal music for a tense scene in a film. It really sounds better with strings. Honest...
That I figured out and replaced modulo with nanosampler strings the first thing. Nanosampler's dulcimer sounds even more ominous than harp
