I would say the last guy was mostly correct. You would definitely need pin 3 tied to pin 1 for MOTU circuit stability and good wiring practices.
SInce the input levels are 1/2 volt for 30 watts of speaker volume, I would connect all wiring with the power off. Turn on the sound source and the MOTU units first making sure there is little or no volume coming from them. Then turn on the Quad 303 and wait for it to settle down. Start your music and slowly increase it's level until some sound is heard. Check your settings and listen for extra system noise, etc. Since the Quad 303 has no volume controls, it depends on the output from your mixer (MOTU 896). If you do hear a lot of system noise and music get's loud quick, you may have to construct a pad for the inputs. The MOTU 896's are capable of +4 db which would be a killer volume level for you!
Here is a link with the specs <
http://www.flashbacksales.co.uk/manualp ... 33-303.pdf>
Good luck! Just some comments from an old audio guy who retired from the sound/electronics industry. If you need further info, send me an email. Be glad to help.
Having fun with 32 tracks in OKC
hp laptop zd7000 2.8 Ghz 1 Gb DDR RAM
XPP SP2 with SP1 FW drivers
Sonar 6.12P
MOTU 896HD (x3)
MOTU Ultralite
many studio mics
email:
hswin@att.net
hp laptop zd7000 2.8 Ghz 2 Gb DDR RAM
XPP SP3 with AVT1394 FW drivers
Sonar 8.31P
MOTU 896HD (x3)
MOTU Ultralite
many studio mics
email:
hswin@att.net
