Hi everybody,
I have my 896 mk3 for one mounth,all working good,
but i have one problem with hi frequency bzzzzzzzzzz noice ,that i hear in headphones then i plug in it in maine out and some less noice in phones out.
Have anybody the same issue ? or it is only one defect? noice is present constantly even the 896 mk3 is in standalone mode
and not depend from volume settings.
thanks for answer
Mac G5 duo 2 ghz,2,5 gb Ram,Logic pro8,DP 5.13...
896 mk3-hi frequency noice
PowerMac G5 dual 2Ghz 2,5 Gb RAM.MacBookPro 2,4 GHz,2 Gb RAM.Logic 8.02. DP 7.12.
- TheRealRoach
Re: 896 mk3-hi frequency noice
This is a well documented prob in the Windows world and is related to one or all of the following:
make sure your Firewire drivers are updated on both your system and 896
another FW device attached to the system that is interrupting the connection
Using a Texas Instruments Chipset based FW card
Mike Rocha
http://www.mikerocha.ca
Custom ADK, Quad 3.0ghz, 4gig ram, Win7 64-bit, Motu 3.6.7.3 x64 drivers
Macbook Pro 13" touchbar, High Sierra, 73220 drivers
Motu 896 x 4
Motu 896 x 4
Try enabling ADAT in/out
Klaus
Klaus
Fanks for reply.
I tried anable and disable all adats ports(Motu recomendated this too), but this dont fix my problem.
Noice is constantly present even the 896 mk3 is not connect to any comps!
And no more answer from Motu...
- TheRealRoach
Sorry about the problems. If you're really not having any luck you may want to read this thread:
http://www.motunation.com/forum/viewtop ... 14&t=31518
It deals with Windows XP, but the symptoms you are describing are identical to the Windows issues. Perhaps there is some way of implementing the fixes but with the OSX equivalent.
I'd be willing to bet that is something about the FW-bus controllers for OSX (not anything to do with the MOTU unit).
Mike Rocha
Motu 896 x 4
Motu 896 x 4
