Superior Drummer, how to save your drum setup?
RockNRoll
Post by RockNRoll »
Hi there,
Using superior drummer with DP 4.6 via rewire. Is it normal for your drum setup to reset itself everytime you close and then re-open a session leaving you to have to go through the routine of setting up your drums again? Is there a way to save your drum setup so you don't have to rebuild your drum set everytime? Thanks for the tips.
nixon72
Re: Superior Drummer, how to save your drum setup?
Post by nixon72 »
Yes it is normal. As soon as the rewire chain is broken, it shuts down. Save your kit early and often.
Dual 2.0, OS 10.4.3, DP4.52, MOTU 828 MKII, IK Plugs, Plugsound, Mach 5, Waves 5.0.
thealtsax
Post by thealtsax »
Hi, DFH superior works so much better as audio unit multichannel with DP 4.6. Try it :)
Power Mac G5 DP 2 Giga - Ram 8 Giga - OSX 10.4.10 - Digital Performer 5.13 - Logic Studio - Unitor 8 MK2 - RME Hammerfall DSP Multiface - Apogee Rosetta AD - Waves Platinum and SSL4000 Bundle - Komplete 3 - Izotope Ozone - MachFive2 2.02 - Tube-Tech MP 1A - Distressor - Neumann U87AI and others things...
