If you want it to sound better, there are options today.
Now, regarding therealbigd's post there are a few things that i have to comment. My views on your remarks are just my oppinions, of course.
If that is your definition of what a Heavy Metal piece sounds like you should check your monitoring, your recording practices or just stay away from making technical comments on music you simply don't like.therealbigd wrote: - style of music: if you are recording heavy, scream-your-heart-out, metal; then there is probably little logic in using a high sample and bit rate. the sound quality gained in the up'd rates are most likely lost in the lack of detail in the sounds used within the track. the guitars are likely to be mushy anyway, the drum kit a tad splashy, and the vocals... well errr.... and all these merely down to the way in which the track is performed. If on the other hand you are recording a string quartet, where the instruments may be much more defined and clear, a higher sample rate could be warranted.
If on a string quartet you have lack of detail on the Cello, mushy Viola and splashy violins, and the musicians are... well, errrr... what would you say? It could happen!
Certainly, higher sampling rates will require more power from your CPU. As will more plugins.therealbigd wrote: - number of tracks / fx used: using a high number of tracks / high number of plug-ins can strain your CPU, and using high rates will only further that. if the project looks like theres going to be loads of overdubs, extra tracks, AU synths, lots of plugins, perhaps a rewire as well; it may be a good idea to be conservative on the amount of data that you are going to apply these things to. a reduced sample rate and bit rate will reduce this actual amount of data.
Maybe it could be advisable as well to use less Plugin Compressors and a higher Sample Rate instead, no?
Besides, people in the studio business have always had technical limitations presented by gear.
If you had a 1 inch/8 track machine you wouldn't record 16 Tracks. One uses what the gear allows.
If you have a less powerful computer/DAW you will use it within its capabilities.
I have a ASUS laptop, 2 year old, Dual Core Intel 1.66GHz with 2GB ram. It cost me in March 2006, more than 2500 Euro.
I record 8 simultaneous tracks at 88.2KHz/32bit with it because that's what my interface allows me. The laptop seems to allow for more since it doesn't even cough.
Nowadays, a faster more powerful laptop costs about 600.
I don't think gear is an excuse to record at 44/16.
Not in 2008.
Dithering has nothing to do with Sample Rate conversion.therealbigd wrote: - the end format: if the track is being bounced for a DVD in HD, by all means go for the higher rates. but if you are going for a CD, why step above 44.1 / 16? many argue with dithering that you can use the higher sample rates to create a nicer sound, so by all means try it... but try dithering without the sample rates and some interesting things can happen too! if the end product is an asetate vinyl / dub plate, where the sound quality will likely be very low anyway, or indeed and mp3 end format, I see no reason to use the higher sample and bit rates, as this additional quality will almost certainly be lost once "burnt" to the media.
Vinyl has a very low quality, you say?
I would say it sounds better than CD.
Maybe because it isn't at 44/16 but, i am not going to convince you anyway, and that is an entirely different subject.
Besides, comparing mp3 and vinyl as the "lower quality" end formats is, in the least, offensive.
As for why using higher sample rates, either go to page 1 in this topic or read again here:
1. get a 44.1/16 audio file. Any length.
Apply a Reverb, a good one. Listen carefully (not with the same system that you listen to Heavy Metal and/or Vinyl records since it seems it doesn't sound that good) check the spectrum.
2. upsample the same original sound file to 96KHz.
Downconvert to 44.1 again.
Listen carefully and check the spectrum.
Notice that they are now, both, at 44.1
They'll sound different and i bet the second one, the one that was converted to 96 before applying the nice Reverb will sound better, more detailed with a better sounding reverb.
The better the quality of the original format, the less it'll degrade after it is played "through some whacked-out PA system".therealbigd wrote: - the purpose of the product: if the product is going to be used within a high def film, or sold as a CD album, etc; a higher sample rate could help you achieve a nicer sounding product. However, if the purpose of the product is for a DJ to play at high volumes through some whacked-out PA system at the local venue, once again, the quality gained by higher rates may be lost by the playback equipment, and further to that the audience of the music is unlikely to notice the difference in quality.
If you start with lower quality, it'll never, ever, get better.
Your advice is: if your gear isn't top notch, don't record well because people will noticetherealbigd wrote: - the recording equipment: if you are using low-end dynamic mics, a cheap desk for pre-amps, and a naff sounding room; the higher sample rates may only highlight this fact. if you are using a nice set of valve mics, into high end pre-amps, through top end converters, from a purpose built live room, the higher sample rates, once again, will highlight this fact. make up your own mind as to which you'd rather highlight, and which you'd rather not highlight.
Higher Sample Rates do not highlight handicaps in recording gear any more than lower Sample Rates hide them.
If your gear is giving you a bad sounding recording, no Sample Rate option will make it sound better. Even if it's a lower Sample Rate.
The contrary may be true.
I say: go for the best that your gear gives you to take the max out of it.
And record carefully and with taste.
Take the truth in consideration and be coherent in your options.therealbigd wrote: overall point - take everything into consideration and make your own mind up!
Learn to listen and develop your aesthetic appreciation of sound.
Improve your earing instead of damaging it.
Learn to listen and appreciate all types of music and sound.
Experiment and judge by yourself when you feel you have attained a better sense of judgement.
And record well.
