Grouping Takes
maxpatch
Grouping Takes
Post by maxpatch »
I'm still on 5.13 - haven't quite dared bite the bullet yet! Here's my question...
If I'm recording some multi-track audio, I like to Create New Takes for each new take. Is there a way of grouping the Takes so that I just have to select another take on one track and all the others follow? So if I switch, say, the choir track to Take 3, the piano track will also automatically change to Take 3. Just had a heart stopping moment when I forgot, and ended up listening to the choir from one take and the piano from another - yuk!
Thank you
Max
DP 5.12; Logic Pro 8; Pro Tools LE 7.4; Sibelius 5; MacBook Pro 2.33 GHz Intel Core 2 Duo; MacOS 10.4.11; Digidesign M-Box 2 Pro; MOTU Symphonic Instruments; MOTU Ethno: MOTU Mach 5; Native Instruments Komplete; Lacie Hard Drives; M-Audio Monitoring
wurliuchi
Re: Grouping Takes
Post by wurliuchi »
You can do that with track grouping, including temporary groups.
DP 6.03 • MacPro 2x3 Ghz Dual-Core Intel Xeon • 9 GB RAM • 10.5.7 • Prayers
maxpatch
Re: Grouping Takes
Post by maxpatch »
Yup - that's what I would have thought. But it doesn't seem to work for me. I've grouped the tracks and all editing functions ARE grouped - I cut, fade, edge edit on one track and all the others follow. BUT select Take 2 in on track and the others remain resolutely on Take 1.
Any ideas? Am I missing something?
Max
wurliuchi
Re: Grouping Takes
Post by wurliuchi »
Go in and edit the group to work with Takes. You're just not seeing it, but it's there. I'd give you step-by-step, but I don't have access to DP right now.
Mr_Clifford
Re: Grouping Takes
Post by Mr_Clifford »
You have to select 'custom' group and click on the take buttons. Not sure why they didn't include takes in the 'edit' group, but they didn't.
If you set it as an 'edit' group, then change it to 'custom' it will come up with all the 'edit group' settings already clicked in the custom box, which makes it quicker to just add the take settings without having to go through the whole list setting everything else up.
maxpatch
Re: Grouping Takes
Post by maxpatch »
Thank you! This has opened up a whole new world of customizable possibilities - brilliant. Thanks again.
Max
