Frodo wrote:magicd wrote:It has long been a common misconception that you can't or shouldn't record to the internal drive of the computer.
Hi Dave:
By "internal drive", do you mean the System Drive itself where a dedicated second drive can also be "internal"? I've *always* had questionable results when using the System Drive for audio recording even on small projects. Pops and clicks are the main symptom even where buffers and work priorities are adjusted in various combos.
I know that one *can* record to the System Drive, but I struggle with understanding how this would be advisable based on what I've seen. I, too, have used DP on various laptops since the G3 days. If you can expound on your point or share some settings, it would be greatly appreciated.
Kind thanks,
Frodo
Hi guys, I record on internal drive of a laptop since many years (1999? I dont remenber...).
Since DP3 (whit Magma+DAE on PT system, pwbk g3), until today Pwbk g4 1,67ghz or Macbook Pro, DP 5.13 whit Apogee AD16X or Symphony, I recorded every time on internal drive;
I have partitioned the drive every time in 2: 1system/apps -2projects (and related audio).
I Never had problem, whit 2 tracks or till 40-50 audio tracks. No VI or real time effect, only audio recording (classic music or similar).
System partition dedicated only to DP, no others programs installed and system-base installation, buffer to 512, prefill disabled, background processing disabled when possible.
Never a problem, never a crash, only sporadically the spinning beach ball for some seconds, after recording a long time of many tracks.
I recorded on this system up to 80 classic music cds. I am very very satisfied of this system, solid as a rock.
I hope DP6 will continues this standard, in Italy there is not landed...
Sorry for my poor english.
