Amplidood's GUI mod 3.5.2 (always updating first post)
Re: Amplidood's GUI mod 2.5 (always updating first post)
Hey glad you like the MID track idea, Andy. Actually, I'm not too hip on the "note" to indicate a MIDI track either and was going to use the 5-pin DIN plug also, but didn't want to make a graphic and didn't want to search DP's PNG resources in search of one. If you don't mind, maybe I'll use yours, but flip it black since my fader background is still light in color?
Interesting aside... since more and more these days we are using VIs, it occurred to me that the 5-PIN DIN connector is almost "old school" any more and it's association with MIDI is going to be diminished in the years to come.
That's the damnedest thing isn't it? Most kids now only know hooking up USB. Wow. It's still appropriate in a lot of cases...there's still lots of hardware being used out there. But it won't be long, right?
Re: Amplidood's GUI mod 2.5.1 (always updating first post)
I can still remember a few years ago... ahem... how absolutely miraculous it seemed when I could play my bass player/Keyboardist's Memory Moog from the other side of the stage using my trusty Roland G707/GR700 combo. MIDI seemed like magic when it was first introduced!
Hehehe... who is THIS guy?
Thank's a lot Amplidood's!
You gave me hope to love DP again,if they fix the other "little" problems.
I didn't like the "official" GUI at all.Boring, unreadable, using the eyes...
Your work is awesome.
Great!!!!!!!!!!!!!
Great!!!!!!!!!!!!!
MacPro 2.66 - 8Go ram-10.6.2 /DP7.2/URS plugs/Kontakt4/PlugsoundPro/StylusRMX/EZDrummer/Superior/Altiverb/Ozone4/Sonnox/etc...Neve 8801/RME ffce 800
- tommymandel
I'm betting it's our Sysop Moderator here....James Steele wrote: Hehehe... who is THIS guy?
(pre-Scruff)
Thanks for the kind words!! Encouragement always keeps me moving forward....melenko wrote:Thank's a lot Amplidood's!
Great!!!!!!!!!!!!!
Re: Amplidood's GUI mod 2.5.2 (always updating first post)
2.5.2 posted....
I finally figured out how to make the new color setup work for me.
1. I use the "Use track color for wave background" option.
2. I then make sure whatever color set I'm using has plenty of color shades that aren't dark enough to turn the waveforms white.
3. I use the darker shades for Auxes and Master fader tracks. That way, on the mixer, audio and MIDI track names are always black letters, while Auxes/Master faders are white letters. Makes for very quick discernment of what I'm looking for.
4. Now when you mute a soundbite, you can actually tell it's muted. The waveforms always being black makes it easy to recongnize muted grey waves.
MOTU could pretty easily fix the muted soundbite color problem by simply make the waveform AND the background greyed out. Not too hard to figure out.
Just Waouw!!!!
Loving all your ideas, dood - one thing I really liked from your earlier versions was the line between channels in the mixer. Is this easy to incorporate?
thx again for all your amazing work.
- Dwetmaster
+1jlaudon wrote:Loving all your ideas, dood - one thing I really liked from your earlier versions was the line between channels in the mixer. Is this easy to incorporate?
Still there with you man...
- Woody
can you explain where these files are to replace for the update thanks
Dual 2.0 G5 w/ 4 gig RAM MacBook Pro Dual 2.4 10.5.4 2 gig RAM. Unable to load DP6 on MacBook but got it on a partition of G5 Dual 2 Gig running 10.4.11
G5 PPC Dual 2 GHz,4 GB Ram,10.5.8,MacBook Pro 2.4 GHz Intel Core 2 Duo,2 GB,10.5.8,DP7.0.1,Peak 4,PCI-424 MOTU 2408 MkIII,MOTU MTP/AV,Tascam DM4800 w/FW Card and Surround,Lucid GENx6-96, Waves 7 Platinum,SSL 4000 bundle,Final Cut Studio,Quested VS2108's,Blue Sky 5.1,Drumcore 3,Misc mics and Instruments
Check the first post...there's a zip of two files two give ya lines in the mixer. Enjoy!!jlaudon wrote:Loving all your ideas, dood - one thing I really liked from your earlier versions was the line between channels in the mixer. Is this easy to incorporate?
Woody wrote:can you explain where these files are to replace for the update thanks
Instructions are right there on the folders with the files.
Amplidood, really like what you're doing. Thanks for all the hard work. A couple questions. how can I use everything from your mod EXCEPT leave the factory pan knobs?
Also, is it possible for me to slightly tweak the darkness of the background colors to make them darker, or is your color choice provided by a graphic file or something of this nature?
