HI All
How do you install iPerformer's mods?
http://www.motunation.com/forum/viewtop ... =1&t=31098
I've read the entire post and couldnt figure it out.
How do you install DarkMods ....for dummies.
Talcott.info
- Dan Walsh
Re: How do you install DarkMods ....for dummies.
Whwn you download and open the file, the folders are detailed in telling you what to put where. It's really quite easy. I'm a computer idiot and I had the dark mod installed in no time flat. You do have to replace the default XML file with the one included in the darkmod folder for the darkmod to be fully operational I believe.
Anyways, download the file, open it and follow the instructions on the folders
Hope that helps.........
iMac 3.06 i3|OSX 10.6.8|8 gig ram||DP 7.24|Motu 896HD|2 Avalon VT 737's|Presonus ADL600|Slate VCC|Superior Drummer 2|EZ Drummer|1.1.6|Kontakt Player 4.1|Steven Slate Drums EX|SampleTank 2 XTAntares ATR-1|Presonus Central Station|Neumann TLM 103|Rode NT1|Audio Technica AT 4033 X2| Rode NT-5's|and lot's of other junk
.....sadly no.
I can read instructions.....but the only ones included with the file read...
Replace the original Default_Style.xml file with this one to complete the DarkMod v.2.0 install.
Enjoy.
iPerformer.
Maybe Im missing somethin....
Enjoy.
iPerformer.
Talcott.info
- Dan Walsh
So... go to Applications-look for DP.6.01. Right click icon to show pkg contentsTalcott wrote:.....sadly no.
Enjoy.
iPerformer.
open contents-open resources-open English.Iproj--
Replace Default_Style.xml with the file included in the Dark mod English/I.prof folder
Then go to the images folder that you downloaded in darkmod and follow the instructions on the images folder. basically you will copy all the images from the dark mod folder into your images folder for DP6.01
That should do it. It worked flawlessy when I did it
Good luck...
This was the bit of info I was missin.
Thank you very much!
....off to post a thanks to the great work buy iPerformer.
Talcott.info
