I plugged in my guitar to the back, had signal, sounded nice, clean and direct. Looked like I could trim the level back a bit, so I turned the knob on the UltraLite counterclockwise and realized that I can't turn it down from there.
I think to myself, maybe I could use the PAD to lower the volume then adjust the trim back up to get the level where I want it. I flip the PAD up one notch to the middle position and it didn't do anything. Great. Up one more notch and still at the same volume. It says in the UltraLite maual the XLR/TRS combo jack are able to use the PADS, but it seems they don't work.
Honestly, after seeing all these posts about the problems people are going through with these things, I am not sure I even want to keep the UltraLite. I know these things are a little screwy with Windows but the front panel should at least work. I can't adjust the level lower at all. I haven't even tried the XLR jack yet to see if the 48V works. Am I so stupid that I am missing something?
Any comments would be helpful.
