using the headphone output on a 1224??
luteman
Post by luteman »
I've been using a 1224 for a while now, but never used the headphone output. After trying to figure it out.....how do you do it? I've routed everthing to the main outs in cuemix but still get nothing on the headphones and the only lights showing are on Analog out 1 and 2...I'm sure people here know how to do this.....any help??
tiger vomitt
Post by tiger vomitt »
does anyone know the answer to this?
i just bought a used 1224 with no manual, i have no idea how to get the headphones to play :lol:
thanks!
socialnumb
Post by socialnumb »
I too have never used the headphone out puts. I can't use cuemix since I'm using pci 324. However there must be a way to rout audio to headphone out on the 1224. I too see out puts 1/2 working but have yet to figure out how to rout to headphones. Some one please shed some light here. I'm at day 3 and failing. :cry:
socialnumb
Day 4 help :cry:
6 :oops:
I'm trying to believe :cry:
socialnumb
Still. Someone out there can either confirm or deny? It appears my headphones out is not working. :roll:
1nput0utput
Re: using the headphone output on a 1224??
Post by 1nput0utput »
The 1224's headphones output mirrors any audio that is routed to the main outputs.
socialnumb
1nput0utput wrote:The 1224's headphones output mirrors any audio that is routed to the main outputs.
Thanks for the reply.
How should I rout this? I think I've tried everything. In the above picture I put it back to default.
Tonio
Post by Tonio »
In bank B (mains) , enable the output to "from computer".
Are you using the AES jacks? Thats what you have set up.
If you want to use the MAIN outs (analog), you need to endalbe them "from computer".
T
Mac Studio MAX 2TB/ 64GB RAM / DP11.2 / 828ES//
MP 5.1 3.33- 3 duo / OS10.14.6 / RX580 /DP10.13/828ES
socialnumb
Tonio wrote:In bank B (mains) , enable the output to "from computer".
T
Thank you for the reply. I am not using the AES jacks. I just want to hear analog 1-2 in my phones. Are restarts needed between each setting?
I'm @ my brothers house for the next 3 months maybe. I took what I thought would be a basic DAW. (to not make noise)
I'm ranting a bit. :wink:
Any help would be highly appreciated.
1nput0utput
T
The headphones output can not mirror analog outputs 1-2. It only mirrors the main outputs. If the main outputs are disabled in the MOTU PCI Audio Setup, then the headphones output does nothing.
Tonio
Post by Tonio »
true dat 1oi.
However, I think there is a jumper inside of the interface that can change that. Don't know for sure, I would have to look in the manual.
T
1nput0utput
Tonio wrote:true dat 1oi.
T
There is no jumper in the 1224.
