Thanks for the piano mic pic! Where did you find that?MIDI Life Crisis wrote:I tend to like a very close mics and place mics fairly close to the rim. I've also used hi density foam cut to the lid openings at 1/4 stick. The sound is very dry, adding reverb later.
1. I'm assuming that the red dots, for instance, are guides for possible placements of 2 mics (bass and treble) with ears being the guide and the same for the yellow if adding 2 more mics for a 4 mic setup.
2. "Foam cut to the lid opening for 1/4 stick"...Again an assumption that the foam would have some kind of cut-outs to allow either room for the whole mic to peek through or at least the boom that supports the mic.
Correct?
Thanks, MLC!
Buzzy
