896HD suddenly not working, unrecognizable by mac
- darrell
hi all. all of a sudden my 896HD has stopped working. ALL led's on the front of the unit keep flashing on and off with it powered up. The Mac audio/MIDI setup does not see the unit. The only 'different' thing I did today was uninstall and then reinstall Clockworks (chasing down a MidiExpress XT problem).
I downloaded (again) and installed the latest firewire drivers off the MOTU site. Still nothing.
help?
Darrell
help?
Darrell
Same problem...did you found a solution yet?
Hi,
I had exactly the same problem with the 896HD on a Macbook.
Did you find a solution? I tried the unit on a Windows XP os and also Windows didn't see the Motu device.
Very unpleasant...is it broke or is it a software thing?
Who helps me/us out?
Goudblad
Goudblad
- bkshepard
Sounds like it might be a FireWire problem.
I've seen several of the MOTU interfaces exhibit the continuous flashing LEDs when they can't connect via FireWire. Try a different cable, different port on the computer, on the interface, and even hooking the 896 up to a different computer. Good luck!
-Brian
Mac M1 Ultra 20-core, OS 15.5, 128 GB RAM, DP 11.3.4, UA Apollo x6
896 Disappearing Problem
Hi guys-
Had a similar problem with the 896HD. Check to make sure the correct selection is made in Audio MIDI Setup/Audio Devices/Audio Output Drop-down (and/or Audio Input). I noticed mine had been inadvertently changed to ADAT when it is actually connected via Analog. After the correction, the 896 reappeared.
Re: 896HD suddenly not working, unrecognizable by mac
Arggh! I've got the same problem. There was a power failure and when it came back on my 896 now just flashes '44.1' but doesn't connect to my mac. Very annoying. Anyone? Help?
I just got the same problem with my original 828... I wrote a TechLink to MOTU... they suggested I reset the voltage selector switch on the side (not sure if your interface has one of those)... just make sure you disconnect the power cord before you do it... just select 230v then back to 115v... I'm not sure if it worked, but you could try that...
M2 Ultra Mac Studio (64GB RAM), 16" MacBook Pro (8 core 2.4 GHz i9, 32GB RAM, AMD Radeon Pro 5600M), Mac OS 14.6.1, MOTU DP 11.02, MachFive3.2.1, 828x, MTP AV, Roland XP-10, DJ-70, SH-101, MC-202, TB-303, Korg ARP 2600m, Arturia KeyStep 37, RE-201, E-Mu Morpheus, Planet Earth, Moog Slim Phatty, Novation DrumStation, Oberheim OB-1, Yamaha 01V96v.2, Mackie 1202 VLZ Pro, Mackie 1402 VLZ Pro, Korg SDD-2000, Roland RSP-550, Roland RE-201, DR-220, Casio PT-80, VL-1, SK-5, Focal CMS 50s
FWIW, I was having problems with my MOTU 896 (*not* HD) disappearing randomly every 10s or so. I've taken the unit apart, examined everything. I just did the voltage input slider thing... voila! It worked!
Fingers crossed, but its been 30 minutes and no audio reset. Seems there's some capacitor or the like that's building up improper voltages and not draining?
- BradLyons
- Primary DAW OS: Windows
FYI there were some Mac's where the firewire port just went out, and have been known to fry interfaces connected to it---including hard-drives. I've heard of this from several clients of mine, no rhyme or reason for it.
Thank you,
Brad Lyons
db AUDIO & VIDEO
-Systems Advisor, CTS
Brad Lyons
db AUDIO & VIDEO
