DP5.13 audio w/ tempo changes?
haydnwalker
Post by haydnwalker »
I've been using DP for years now, but never tried to do this. Is it possible when you change tempo in the conductor track that you can easily have all the soundbites you've already recorded to sync (time stretch/compress) with new tempo just like the MIDI?
2x2.66 GHz Mac Pro Dual-Core Intel Xeon w/ 5GB RAM, MacBook 2.4 GHz Core 2 Duo w/4GB RAM. DP 5.13, East West Platinum ProXP, East West PLAY (Goliath, SD2) BFD, Spectrasonics Atmosphere + Trilogy, Stylus RMX, Kontakt 2, Ethno instr. and MSI.
David Polich
Post by David Polich »
Yes.
Just select each track and highlight, set its start and end times to whatever portion you need to adjust (I usually just set the start and end times to the full length of the sequence). Then under the "audio" menu you select "adjust soundbites to sequence tempo". It's a good idea to just do two or three at a time, not all the tracks at once. If it's a long sequence I stay on the safe side
and just do one track at a time.
DP will create a bunch of new soundbites with addendums to the names, like
"Kick.1", "Strings.1", etc., for each time you do an adjust soundbite command. If the tempo change is more than 8 BPM in either direction, your results may vary - I've sometimes ended up with soundbites that were out of whack because they just didn't "adjust" well. Usually these are things like string pads, organ parts,guitar solos, anything that doesn't have a lot of percussive transients. Make sure you backup your project first before you start adjusting soundbites.
haydnwalker
hahaha. Thanks. Funny that was there all the time and i didn't notice it. eeediot! i could've saved my self a little bit of trouble in the past had i known.
Nice one my friend.
