Work Priority
kassonica
Re: work priority
Post by kassonica »
jlstcui wrote:Hmmm. I did a bit of DP6 manual reading the other day, and though I haven't yet installed the new version (I'm happily running 5.13), I did decide to apply one of the manual's general suggestions: change work priority to "High."
Since then, I've had considerable trouble getting any decent number of VI's to playback together properly. I'm thinking of trying "Medium" again, if not low.
I run an older MOTU audio interface, the 1224. Is it possible that I should now be thinking of trading up to a newer interface, and if so, which would be best?
What computer do you use to run it?
jlstcui
Post by jlstcui »
It's a Dual Processor G5 2.0, with 4 gigs of RAM, running OS 10.4.11.
(Nice avatar kitty.)
toodamnhip
Post by toodamnhip »
That's my question too...
Does putting the work priority on Low give one extra computer power to run VI's?
When the comp is crunching, is it a valid thing to try when one has an 828 mkII for example?
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
bOing
Post by bOing »
I've had years of trouble free performance through my RME ADI 8 DS, Digiface and HDSP card. Recently after installing DP6 and running a few VIs and recording a few guitar tracks I ran into crackle city. I thought I had to go buy something new...
Anyway, I think this post has cleared up part of my dilemma ie work priority. (I'll test it in a few minutes). An update should clear up the rest.
Thanks UNIs.
Success is just one more plugin away! And happiness is as close as your next upgrade.
I think I set mind to Medium a long while ago and have not touched it since. I don't see much use in "High." Either the app works or it doesn't. :D
