2408 mk3 is not seen in MOTU Audio setup
Aramis
Post by Aramis »
First of all , I am reading your thread and I am wondering if you could have a pcie hardware problem since the begining .
But I wanted to add that , I do own a 828 mkIII and installed in a Mac Pro and it does work perfectly . I have decided to go firewire because of the fact that they change so many time the pci thing in the computers that you cannot re-use your stuff at some point in time .
I made readings about firewire and the bandwith is very good for audio and firewire does not use the cpu compared to usb .
The thing to remember is to not use a bunch of other devices on the same firewire connection witout analyzing what you do .
Plus , there is always the solution to add a pcie firewire controler to separate the devices . And , if you do want more hard disks , do not use the same firewire connections and preferably add SATA drives .
And finally , remember that if your 24 i/o has adat connections on it , it could be used on the 828mkIII easily in standalone mode . I do use my old 2408mkII this way right now on my 828mkIII .
Aramis
Ya'll are making me think twice about upgrading to a 424e??
Maybe I'll go for a FW interface afterall.
I could do that also since I have an 828 mk3 here also. But I thought the whole idea behind FW interfaces were geared toward the laptop crowd. I mean if you have hard drives and other miscellaneous stuff hooked up firewire to your Mac Pro, does it make sense to connect your audio interface FW also? I thought the whole idea behind the PCI card concept was to keep that signal path somewhat isolated. And then for me there's the whole issue of the 24 i/o. That's not compatible with the 828 mk3. But with the problem I'm having right now I could sell the 2408 mk3 and the 24 i/o and go firewire. Does that make any sense?? Any thoughts on that, anyone? It seems backwards to me.
scooter[/quote][/quote]
iMac 2012 27 ' 3.2 ghz 32 gigs ram OSX 10.9.4 DigitalPerformer 8.7 , MOTU Track 16, MOTU MachFive3.2, Ethno and BPM , Komplete 9, OmniSphere , Trilian and Stylus RMX , Axon mkII and Godin LG .
Aramis
Post by Aramis »
I would be interested to know where you have found the information about the fact that FIreWIRE takes some cpu cycles with larger latency margins ?
Remember that between the 424 pcie card and the 2408mkIII , there is a proprietary firewire link wich does the same as a regular normal firewire bus . So , I do not see any issues about the clocks and converters .
Aramis
Tonio wrote:FW,agreeably may be more for the portable types. PCI does have more bandwidth as far as I know. Also doesn't FW take some CPU cycles with larger latency margins?
ah, but what about the convertors/clock being in the computer issues??
I would rather get a PCI card for budgetary reasons, but with these reports I wonder if getting upgraded convertors in an FW interface will be a better side move in the end?
T
Aramis
Post by Aramis »
Oh! and by the way Aramis , do not forget that the most recent Mac Pro do have more bandwidth on the firewire to mother board link !
Very important !!!!!
Aramis
Aramis wrote:First of all , I am reading your thread and I am wondering if you could have a pcie hardware problem since the begining .
Aramis
scooter
[/quote][/quote]
Aramis
Post by Aramis »
Ok , here is a mistake , the 24 i/o does not have adat connections . So you would not be abble to use it standalone with a 828mkIII .
Sorry ! my mistake ...
Aramis
Aramis
scooter
[/quote][/quote]
scooter
Post by scooter »
PCI card changes over the years kind of drive me crazy too. It's definitely one reason to go FW with the audio interface.
scooter
Macbook Pro OS 10.12.6, 2.6 GHz Intel Core i7, 16 gig memory, Apollo Twin audio interface.
Tonio
Post by Tonio »
Aramis,
I was questioning if FW on the MAC uses CPU cycles, as I have heard such implications. Even though the 2408mkxx uses a FW implementation between the 2408 box and PCI card, the card uses the PCI buss architecture on the MAC. So you are saying the PCI/box interfaces have a FW buss chip identical to FW bus chip on a MAC?
I recollect that the 424 PCI have the clocks on the card itself. vs a FW interace all the clocks /convertors are in the interface box. PLease correct me if I am wrong.
I would like to hear more about the above architectures.
T
Aramis wrote:I would be interested to know where you have found the information about the fact that FIreWIRE takes some cpu cycles with larger latency margins ?
Aramis
T
Aramis
Post by Aramis »
Tonio
Yes , indeed , that is what I am saying . The link in between the pci 424 card and the 2408 box is a proprietary firewire . So , I do not think the mechanism is so different between the 424/2408 and an 828 for data exchanges .
Of course if you fill the 424 card with 4x 2408 boxes , ou get more i/o's than the 828 but this same 828 has a firewire extra connector that MOTU say you can use to add some other firewire motu interface . But I do not know precisely how many .
Aramis
Tonio wrote:Aramis,
T
Aramis
T
