DP6: slow response times
MikeH
Post by MikeH »
Whenever I record enable (and disable) a track, or select an item from the pulldown menu at the top, the response time is really slow. No problems during recording or playback, though. Any idea on what might be causing this? In general things seem to respond much slower than when I was on 4.6.
Leopard 10.5.4 PowerMac G5 dual 2ghz 4.5 GB ram.
MikeH
Post by MikeH »
anyone?.... I tried changing the work priority, buffer settings, etc. but nothing changed.
Timeline
Post by Timeline »
hmmmm maybe machine, do kno
Tonio
Post by Tonio »
hm , hmmm
Hey Mike, made the jump from DP4.61 eh? I'm in the process of that me-self.
What interface are you using?
Work priority is really based on the interface. What buffer are you at?
T
homebilly
Post by homebilly »
i have an 8 core and this is driving me crazy too!
it doesn't make any sense
el Ocho 2.8 running DP6 & RMX with M5II - 828mkII / el Quatro 2.66 running Vienna VI & Vienna Ensemble, RAX 2, M5II & L8 for VSL - 2408mkII / steiner MIDI EVI, Oberheim Xpander, M5II reading UVI .dats, Radium 61 controller
http://www.ronmeza.com
Paris mini studio : iMac 20" intel 2.66 core duo (spring 2009) DP 6.02 - Firebox running M5II & Independence Pro 2.1 connected to Mac Mini (spring 2009) - Firebox running L8, RAX 2, Independence 2.1, M M5II
Keystation 49e controller
MikeH
Post by MikeH »
I'm currently at a 512 buffer. I'm working totally within the computer- there's no external audio interface. I am however using the MAS support bundle from 4.61 because Kontakt 2 won't work with the version 6 one. Could that be slowing things up?
martian
Post by martian »
did you try turning prefill buffs off? I was having similiar issues and it helped..
http://www.fork-media.com
MikeH
Post by MikeH »
just tried turning the pre-fill buffer off, but nothing changed. still experimenting.....
kassonica
Post by kassonica »
Make sure that Automatic beat analysis is turned off as well.
martian
Post by martian »
MikeH wrote:I'm currently at a 512 buffer. I'm working totally within the computer- there's no external audio interface. I am however using the MAS support bundle from 4.61 because Kontakt 2 won't work with the version 6 one. Could that be slowing things up?
well you could try switching them back temporarily and see if it helps...
MikeH
Post by MikeH »
turned beat analysis off and restored all the AU plugins to DP6 standard (except the MAS support bundle- it stayed at 4.61). Still no change. I timed the response times and it averages about 6-10 seconds of "thinking" before I can go on with my work. This happens when record-enabling/disabling tracks and even when selecting items from the top pull-down menus.
martian
Post by martian »
that would drive me nuts..,,
I'd definitely updating the support thingy to 6 - see if that is the cause..
perhaps some kind soul will send you the support bundle from v5? maybe that would work better?
MikeH
Post by MikeH »
thanks martian. oh, I forgot to mention that the reason I'm using the 4.61 MAS bundle is because DP6 crashes immediately when trying to open Kontakt 2 with the version 6 bundle. But you're right, perhaps the bundle from version 5 would solve it....
martian
Post by martian »
i think you need to isolate the issue first -
forget about Kontact for the min..
put the proper bundle back is that the cause?
if yes - ie squashed the slow bug -
then u might try the v5 bundle?
Eleventh Hour Sound
Post by Eleventh Hour Sound »
Deleting and rebuilding your audio bundles may help. (The input, output, instrument, and busses). BTW: does anyone know how to get rid of instruments (like Ableton Live) that are showing up in the instrument window with out uninstalling them? Could they be a source of slowdown?
DP11.1, 16" MacBookPro 2.3Ghz 8 Core i9's 32GB Ram 1TB SSD, (2) external 1TB Samsung SSD's , Steven Slate SSD 5.5 and Trigger Drums, ML-1 Mic and VSX Headphones, Omnisphere 2, Trilian, Ivory2, EW, MSI, MX-4, Philharmonik 2, Komplete, Reason, Live, Melodyne, IK Multi's Total Studio, ARC, T-RackS, SampleTron, AMG's KickA--Brass. and my beloved guitars :-)
