This is a very NOOB question so hang on.
I just purchased a 192HD along with most of the other items to get a home studio working i.e. powered JBL monitors etc.. and in trying to set things up, I've run into a snag...
How should I connect and set up my monitors? I've tried several options and had basically the same problem. From Nuendo I've routed the output of the stereo out bus to the 1 and 2 outputs on the 192, I've also tried other outputs and when playing back, I always get a tremendous amount of signal on the right channel which is highly distorted along with some scratchy distortion on the left channel.
Any ideas? This is rather frustrating, since I know it's not the monitors and the signal at the channel level is not over-driven but between the channel output and the stereo output bus, especially the right side, the signal strength goes way up.
Any help would be appreciated.
thanks,
Seting up Monitors with an 192HD
Gary Birch
